DAVECS1
Turn the pry bar 180 degrees from how you have it in the picture, then just twist it while rotating the axle back and forth. Don't get too nuts twisting the pry bar as it will be up against the seal. If the seal does get damaged they are pretty cheap. Basically you just need to get the snap ring started in the splines and rotating the axle with a little pressure will find the sweet spot.
