How often does tire pressure update, and cleaned up pics
SVTFreak
#275
Prairieville, LA
2015 Wimbledon white LE #275 A6
How often does the tire pressures inside update? When cleaning up the car, I heard what sounded like air leak squealing at the front passenger tire. I didn’t see any bubbles. Even think I smell rubber but it’s brand new so could just be tire. But the pressure inside hasn’t changed a single psi. Showing the same it has been. The key was in the car, but it didn’t really sound like an electronic sound, but maybe could have been? Went to get a video of it but it was gone then, if it is a leak, water must’ve run off that area. Anyway, pics for just because.
rp930
CO
Rick
2021 Shelby GT500, 2019 Ranger, 2015 MB GLK250
I had that problem also. I had to delete the app twice and reload before it worked. I have two cars on it and they were both reporting incorrectly.
SVTFreak
SVTFreak
#275
Prairieville, LA
I’m looking at the one in the car. My app is showing the same as the car at the moment. I haven’t drove it other than to put back in the garage, but the tire pressure hasn’t changed in a couple hours. If it really was leaking so much I could hear it, I would think it would be a lot lower.
Which begs, if it wasn’t that, wtf did I hear?
The Chairman
South TX
‘09 GT500KR & ‘16 GT350 Track Pack & ‘20 GT500 HP
I’ve noticed my TPS readings update on all my vehicles immediately after I start the car. Then they increase as the tires warm up. So it must read nearly realtime.
- I installed a new set of Cup-2s the other month and the readings updated as soon as we started the car because one read zero and they had to reset the system.
As to the sound you hear, might be the Air Conditioner bleeding down. The expansion valve is behind the right front wheel.
SVTFreak
SVTFreak
#275
Prairieville, LA
thanks man for the info. I see (in app) that it’s still good pressure. I’ll go check it in a little while with my gauge.
