How much can the OEM fuel pump handle?
ero 5.0
Bay Area, CA
Eric
2015 mustang gt 5.0
So I currently am sitting at about 470 rwhp on E85. I was thinking of either doing cams or maybe a 100/150 shot as my next mods. How much more until you think a boot-a-pump is needed? Thanks.
Hoblick
Ohio
2015 Mustang GT PP
I was recommended to do a boost-a-pump if making over 600.
dubster99
Nor*Cal
2015 Ingot Silver GT PP
I asked this question in the FI forum and couldn't get a straight answer....E85 plus nitrous on the stock pump. With cams you will absolutely be fine. With nitrous, I don't know. A BAP would at least give you peace of mind. And you can always swap the vacuum gauge for a fuel pressure one to keep an eye on it.
Derek@Lethal
Wellington, FL
Derek
2012 Mustang GT 300A w/ Brembo's
This would be true on a gasoline based fuel, but things change dramatically when using E85.
ero 5.0, if you plan on using nitrous you will need the BAP immediately. Staying NA up to around the 500 rwhp area you'll be fine without the BAP, but you'll need cams to get to that point. Hope that clears things up, let us know if you have any other questions.
Thanks. :thumbsup:
ero 5.0
ero 5.0
Bay Area, CA
Eric
2015 mustang gt 5.0
Thanks. :thumbsup:
Thanks all
