Hood flex with strut addition
NewTekBuzz
Flint, MI
Tim
2019 velocity blue GT 6M - 2015 Black GT 6M (sold)
I have added the redline struts to my car... I cannot believe how much the hood flexes at the hood mounts! Should I be overly concerned?
Thanks
MIKESHIP
Virginia
MIKE
2015 MUSTANG GT
Put mine on the other day and have no flex
gunsnbutta
its just a 2 door fusion
Dallas, Texas
TJ
2019 Mustang GT
Why would/could hood struts cause the hood to flex?
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
It just seems like where the hood meets the hinge, the struts keep it from rising any further but if you lift slightly on the hood out at the end it really feels weak.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
Guess the flex is where the hinges mount to the hood, not the entire hood itself
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
The hoods are aluminum so they will flex. The mounting points become the fulcrum however it won't be an issues unless you plan to leave your hood up in windy conditions or for days/weeks on end. You'd have the same issues with using the stock hood prop rod....
BumpnRun
I bleed FORD Blue...
Northern California
Tom
'65 Mustang '08 Edge ltd '98 F150 50th ann
I installed them also, and noticed the very same thing your describing. Obviously Ford didn't reinforce that area of the hood around the hinge mounts because they knew that a hood rod would be used. I am very careful closing my hood when taking the hood load off the struts at the top.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
You don't have the same issue with the prop rod because there is nothing restricting the hood at the hinge.Was just wondering if others have seen the same thing. I wouldn't want to leave it up on a windy day, that's for sure.
4 ROUSH
NONE
COMMUNITY
SOLD
This will probably be dealt with down the road, in a different model year. This why i did not use hood struts and left the prop. I have hood struts on my 2014 5.0. You will notice a lot of flex in different areas of this new design. Maybe thats why Ford still kept the prop rod.....:headbang:
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Disagree...put the prop in and grab the opposite side corner of the hood and pull....plenty of flex. Leave the hood propped up long enough and that corner will start to sag.
