TheNameAndy
So just wondering if this is normal or not.. When I press the clutch to start the vehicle, sometimes I hear a "hissing" (releasing air pressure) sound coming from the clutch area.
Could you take a video of it? Might be normal. Mine isn't quiet either.So just wondering if this is normal or not.. When I press the clutch to start the vehicle, sometimes I hear a "hissing" (releasing air pressure) sound coming from the clutch area.
When it's quiet would be the time to be concerned :headbonk:That is the fuel pump priming taking place.
Thanks for the replyThat is the fuel pump priming taking place.
Completely normal.
You bet. Push it in again, let off, then push the clutch again. It should not make the noise as the priming is completed.Thanks for the reply![]()
Correct. I tried it!You bet. Push it in again, let off, then push the clutch again. It should not make the noise as the priming is completed.
Yes I noticed it would only do it once.You bet. Push it in again, let off, then push the clutch again. It should not make the noise as the priming is completed.
