Help me Steeda- TRIAX shifter problems.
B4RK3R
CRWDCTRL
Western NC
Andrew
2018 Ruby Red GT Premium
Steeda, I'm hoping you can help me with a huge problem I'm having after installing my Tri-ax short throw shifter. After following the installation notes and CJPP video to a T, my first gear is now reverse 95% of the time. Reverse can be achieved without pulling up on the reverse lock out, and all the other gears are extremely hard to access.
Before I decided to write this post, I did almost 5 hours of attempted problem solving, and google-ing.
I tried the following:
-took out the factory shift spring (google says the spring is a common
problem)- no change
- loosened and tightened the reverse lockout bolt- no change
- Took off the shift boot- no change
- tried it with and without stock shift knob- no change
- tried multiple combos with and without things, all with the same result. Ive installed and uninstalled these so many times I ended up breaking my shifter bezel and stripping out the steeda delrin reverse assembly :frusty:
I installed the triax parts with the steeda shifter bracket base and the steeda lockout collar.
Steeda, I know this isnt a common problem, but it has been a problem for people before. Everyone seemed to have solved their problems, but none of them say how. Can you help me out here?
tj@steeda
Timothy
Hello B4RK3R,
Please send me your contact info, order number & details on the box - we'll have our installation team give you a call & discuss what may be taking place.
Best Regards,
TJ
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
problem)- no change
Please pm a photo of the installed lockout collar, so i can see how it is assembled.
Thank you ,
Steeda Tech
B4RK3R
B4RK3R
CRWDCTRL
Western NC
Andrew
Thank you ,
Steeda Tech
Thanks for the quick reply Steeda. At the moment I'm re
-installing everything from the beginning. As soon as I get to that point, I'll send you a picture.
B4RK3R
B4RK3R
CRWDCTRL
Western NC
Andrew
@steeda... Couldn't figure out how to upload pics in PM on my phone so I'll have to do it here.
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
In the last picture shown does it shift fine without the lock out upper collar and knob. Just pull up on the delrin lower collar to get it in reverse?
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Also, make sure you do not over tighten the guide set screw. The delrin lock out collar should move freely up and down to keep it from going into reverse.
B4RK3R
B4RK3R
CRWDCTRL
Western NC
Andrew
I have the aluminum lockout collar from you guys.
Also, as the last picture shown, it works flawlessly up until that point.
B4RK3R
B4RK3R
CRWDCTRL
Western NC
Andrew
Ok.. So yeah, I was able to put it in reverse with the picture as shown, without using the collar... This isn't making any sense...
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
More than likely it is hanging up on the billet collar , Check to make sure it is centered properly. It should move up and down smoothly. Which shift knob are you using?
B4RK3R
B4RK3R
CRWDCTRL
Western NC
Andrew
I'm using the stock shift knob.
B4RK3R
B4RK3R
CRWDCTRL
Western NC
Andrew
Can't be this, the car with go into reverse with the billet collar uninstalled.
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
With the delrin fully seated in the down position? You can see where it can't go past the reverse gate, if it still goes into reverse with that being said the lower plastic cup may be installed wrong.
pm your contact info and I will call you in the am.
Thanks Steeda Tech
B4RK3R
B4RK3R
CRWDCTRL
Western NC
Andrew
This is what the shifter looks like with just the Delrin collar all the way down. Looks normal to me, but I'm not certain. I'll send you a PM. Thanks.
B4RK3R
B4RK3R
CRWDCTRL
Western NC
Andrew
HUGE shout out to Steeda. Jamie called me yesterday morning and walked me through a few things it may be. after fiddling around with his suggestions, the shifter seems to work perfect! This thing is very picky, but when its set up it feels great! Thanks again guys. :headbang::cheers:
