Help identifying this part left side of trunk and help locate rattle/buzzing sound
DaveN
Mid West
17 Mustang Convertible Eco Premium
My 17 conv just started making a rattle/buzzing sound coming from the left rear of my backseat trunk area. I just can't pinpoint it. I found this and it does have like a rattling sound to it when I tap on it. The crazy thing is the buzzing sound is only when the top is up. Can anyone identify this part? It has as cable leading up under the rear deck lid. Also this buzzing sound, anyone else with this problem.
Sound Wave
Honolulu, Hawaii
Gary
2015 GT 50th Anniversary Limited Edition MT
It is hard to get a feeling of where that is, but from the look of that picture, it looks like part of the trunk lock actuator system.
Tim_
UK
Lightning blue S550 Coyote convertible
Yep it is, looks like it’s where the physical key goes in for manual boot release.
If I’m right then you can get to the other side of it (interior side) by pulling the rear seat side bolster to one side and check to see if there’s any issue there. There’s a diagram in the owners manual of where the key slot is.
ORRadtech
Atlanta, Georgia
This is the correct answer.
Getting to it from the inside is easier said than done though...
DaveN
Mid West
Thank you. Will check my manual before posting next time. For sure going to invest in a service manual. Need pictures to take things apart looking for the rattle/buzzing sound.
Tim_
UK
lot might not be the source of the buzzing but it’s an area to check. Even give it some lubricant and a dozen turns with the key in as that might help.
DaveN
Mid West
I think it might be this carpeted panel. Need to figure away to fasten this panel down better. Does rattle/buzz when I tap on it
DaveN
Mid West
In this photo the weight of the top is enough to stop the rattle/buzzing sound.
ORRadtech
Atlanta, Georgia
The trunk carpet/pad? I'd try putting something like a fiber insulation under it.
DaveN
Mid West
I identified and fixed the annoying rattle/buzzing sound. It was these plastic retainers that came loose. Just needed to push a few back in and problem was solved. Few hours looking for the problem and 10 seconds to fix. Was interesting to see how Ford made a channel and drain tube to collect water from entering the car. Thanks everyone!
ORRadtech
Atlanta, Georgia
You might want to check and clean that drain occasionally. They've been known to clog and wet the interior. There are drains in the front cowl as well. Especially if it's parked outside.
