DANA44
- Dec 27, 2015
- Central Connecticut
- Dave
- 2016 v6 convertible
I removed the tumor on the stock intake air box. The Helmholtz resonator was decapitated with a hand saw gaining access to a ridge in the base housing. Within the ridge I set a nylon washer 11/4” OD. Using a hole saw 15/8”cut out a blank from the scrap piece. 3M DP 190 epoxy was used to bond the nylon in to the ridge along with bonding the cap that was derived from the scrap piece to the base. The SS cap bolt and lock nut were used as part of assembly but can be removed once the epoxy is cured a logo item can be epoxied to the cap if desired . There is a deeper tone at WOT not day and night but there.
[/url]https://flic.kr/p/HzewZf
