beefsupreme
I have a 2019 EcoBoost with 61,000 miles, and like the prior model years the climate controlled seats have failed. The thing is, Ford changed the design and I can’t find any information relevant to my car in the forums. I don’t see the typical offending module with the burnt ground pin under my seat.
Problem summary:
Problem summary:
- Fuses 12, 13, and 14 are intact.
- Heating at any level doesn’t work on the driver’s seat. The light comes on and nothing happens.
- Cooling at any level doesn’t work on the driver’s seat. The light comes on and nothing happens.
- Neither heating nor cooling cause any air to blow at all.
- The passenger’s seat cools fine.
- The passenger’s seat heats, but the air doesn’t blow as loud as when it’s cooling. Level three heat is about as loud as level 2 cooling. There doesn’t seem to be a difference in air speed between level 2 and 3 heating.
- The usual passenger is from Eastern Europe and has strong negative beliefs regarding the health impact of air conditioning. Thus the cooled seats on the passenger’s side are never used and the heated seats are usually used at level 1 and sometimes level 2.
- I typically drive with the climate control seats maxed out because as we all know, after 15 minutes they stop working anyways because the same air gets recirculated through the TED within the seats. Seats are really the biggest weak point on the Mustang’s design… longevity, build quality, comfort- all lacking.
