Heat Issues
blakedanatural
West Chester,Pa
Mustang 5.0 Premium
Hello All,
My 2015 Gt Premium with 49000 miles is blowing cool air with the temp set at 84. Expressway driving the the air becomes warm like normal but when I come to a stop( with the fan set high)cool air is coming out the vents. Is there a recall for this or is this sound like a thermostat repair? I hate to go to the dealer to hear mention a 500.00 repair. I checked my coolant Ievel and it was below minimum. I will add coolant and see if this helps. Appreciate any help with this matter or if there is already a thread please direct me to it. Thanks again Mustang6g
Shifting_Gears
South Florida
There is a design flaw in the AC evaporator core. You will find MANY threads documenting the information on the forum. Yours probably failed.
Unfortunately it’s a big job to replace, assuming that’s what it is. Your engine coolant level won’t affect your AC performance, two separate systems.
EDIT: Sorry, read your post wrong. Most people would hope for your issue versus what I mentioned lol.
blakedanatural
West Chester,Pa
Mustang 5.0 Premium
Ok thank you. I cant figure it out.
angermgmt14
Massachusetts
2016 GT Premium--Oxford White--A6
Is is blowing cool air out of all the vents? Last year I had an issue with only the 3 vents from left to right blowing warm air and the other 2 we're blowing cool air. They determined it was the blend door actuator and it fixed the issue...so far.
Lime1GT
Winnipeg, Mb. Ca.
Thomas
2017 Mustang GT PP
If your rad hoses are hot after driving a long time it's unlikely it's a thermostat problem. If you can see coolant in the coolant degas container it's unlikely to cause a heat problem if slightly below minimum. A defective A/C evaporator would cause inefficient or no interior cooling not a poor heat problem. Likely as angermgmt14 said it's a blend air door problem. Either the actuator may be defective or the blend air door may be broken. I know my old 05 had a HVAC reset procedure that could be tried before looking for other defects but I don't have a 15 manual, to verify if it's HVAC controls can be reset to default as well.
I
