Heads-up on Roush hood strut kit on a '19 Bullitt
Discussion in '2019-2020 Bullitt Mustang' started by aileron, Oct 16, 2018.
  1. aileron
    aileron Well-Known Member
    First Name:
    Dick
    Vehicle(s):
    '19 Bullitt K1191, '20 BMW X3 M40i, '14 Ram truck...and 19 old Triumph motorcycles
    May 1, 2018
    Montana
    265
    159
    Occupation:
    Aviator
    0   0   0
    I finished the installation of the Roush 2015-2017 Mustang Gas Hood Strut kit today. I chose the Roush version because it has much more structure on both the hood and fender brackets compared to to others models. It's stronger, but no one seems to have problems with the other brands...but I'm an engineer and like things built hell for stout.
    There's a gotcha though: the fender brackets are about 1/16" too tall and may hit the hood when it's closed ! :whew: Roush is aware of the concern and had me grind about 1/16" off the top of both brackets to ensure clearance; I used a thin slice of cheddar cheese on to the top of each bracket, closed the hood, and then measured the clearance. After grinding, i have about 3/32" clearance - not a lot, but enough. It's possible the brackets could deform the underside of the hood if you weren't aware of the potential problem.
    Apparently the '19 Bullitt hood is different than other Mustangs; hard to believe, but Roush engineering was already aware of the issue.
    aileron
  2. 16Fastback
    16Fastback RMR 8985
    First Name:
    Stephen
    Vehicle(s):
    2016 Fastback , 2009 Ranger 4x4
    Jul 17, 2016
    Pennsylvania
    464
    450
    Garage Profiles:
    As long as your happy,I have redline hood struts been to plenty of car shows with the wind blowing pretty good and they held up just fine. Its an aluminum hood not much weight there.everybody has there reasons the reviews for redline were great so that's why I chose them.
  3. OP
    aileron
    First Name:
    Dick
    Vehicle(s):
    May 1, 2018
    Montana
    265
    159
    Occupation:
    Aviator
    0   0   0
    In hindsight the RedLine version may have been smarter if it works w/o modification for a '19 Bullitt.
    16Fastback likes this.
  4. POJ 1
    POJ 1 Well-Known Member
    First Name:
    Phil
    Vehicle(s):
    2019 Bullitt build no.301
    Mar 19, 2015
    Auckland New Zealand
    704
    249
    0   0   0
    What makes you think the bullitt hood is any different to a GT hood?
  5. OP
    aileron
    First Name:
    Dick
    Vehicle(s):
    May 1, 2018
    Montana
    265
    159
    Occupation:
    Aviator
    0   0   0
    Only that Roush engineering in Michigan told me they've seen a problem on Bullitts - I don't know if '19 GT's have the same issue.
  6. Bullitt
    Bullitt Well-Known Member
    First Name:
    Vehicle(s):
    2019 Mustang Bullitt
    Jun 11, 2013
    Pittsburgh
    2,110
    1,577
    Rating:
    100%
    1   0   0
    Interesting about the Bullitt hood being different, I wish they'd elaborate. Thanks for the info though! I do know the insulation on the underside of the hood is different to create a seal with the open air box but don't think that would affect the strut area so I'm really curious what else is different.
  7. POJ 1
    First Name:
    Phil
    Vehicle(s):
    Mar 19, 2015
    704
    249
    0   0   0
    Before I ordered my redline hood struts in July I had it confirmed by email from Redline themselves that their struts would fit the 2019 Bullitt
  8. AC53
    AC53 Well-Known Member
    First Name:
    Alan
    Vehicle(s):
    2019 Bullitt K0234, VW Touareg TDI, Lincoln MKZ, etc.
    Apr 25, 2018
    NS
    138
    89
    0   0   0
  9. OP
    aileron
    First Name:
    Dick
    Vehicle(s):
    May 1, 2018
    Montana
    265
    159
    Occupation:
    Aviator
    0   0   0
  10. AC53
    First Name:
    Alan
    Vehicle(s):
    Apr 25, 2018
    NS
    138
    89
    0   0   0
    Good on them. Hard to catch Jack sleeping. ;-)
Loading...
Share This Page
