headers ATAK fitment
svtfever
ALEX
TX
William
2019 GTPP1
what headers would bolt up best to my 3in atak CB besides borla. I am looking for a 1 3/4 design.
bravohankins
Chandler, AZ
2015 Mustang GT Premium, Ingot Silver
I have a Borla 3" S-Type Catback.
When I had AFE Power LT Headers with HF Cats installed by a local performance exhaust shop they had to fab/weld in a 2" long piece on each side to make a 3" performance connect work.
The AFE's came with a connector to the 2.5" mount point used by catbacks, but I wanted 3" the whole way. The 3" Borla LT Header extensions only work/fit if you are using Borla's catless headers.
So we were left with about a 2.5" inch long gap between the AFE and the Borla. The shop cut sections of the Borla 3" extensions and welded them in to close the gap and make the 3" performance connect. They did a nice job with it and its a clean looking job and all T304 stainless, not anything I could have done on my own though.
marylandspeed
Southern MD
Mustang
Pretty much any headers will connect since the 3" Borla still uses OEM connections up front. We have a pretty awesome deal if you call us @ 443-730-9428!
beefcake
Bethel
2018 Ford Mustang
you have some nice options out there in 1 3/4 or 1 7/8, all will work well and bolt up
we also have the pypes in stepped 1 3/4 to 1 7/8
hit us up with any questions on pricing and install
Derek@Lethal
Wellington, FL
Derek
2012 Mustang GT 300A w/ Brembo's
Do you want the system to be a bolt on affair or do you want to have a full 3" exhaust?
For a bolt on affair, pretty much any kit out there that is considered direct connect or factory connect will bolt up to the Borla cat-backs. American Racing, Kooks, Pypes, Stainless Works, Stainless Power, AFE Power, etc, we have them all. My recommendation to you would be American Racing, Kooks or Stainless Works as well as select others. If you are more looking for a certain price point, let us know and I'm sure we have something that will fit into your budget. Note: Most kits will be 1-7/8" primaries, but there are some 1-3/4" options available on our site.
If you want a full 3" system, the American Racing Bottle Neck Eliminator kit would be just what you are looking for. This system will eliminate the OEM 2-1/4" connection and cross over that is built into the cat-back and give you full 3" exhaust as well as a much more efficient ARH cross over (H or X). They do require cutting but instructions and hardware are included.
Hope that helps clear some things up, if you have any questions, please contact us.
Thanks :cheers:
