SpArKy
- Jun 24, 2016
- Eaton Bray, UK
- Steve
- Mustang GT
I bet that sounds awesome.There’s nothing wrong with any of the dsps you listed, they’re all respectable brands. At some point your chasing something that may or may not even be perceptible.
The setup is as follows:
JL Fix82 to flatten the factory signal
Helix DSP for processing
Helix Director to control setups and sub volume
Morel MT350 tweets
Morel CDM880 mids
Dynaudio E650 midbass
Pair of Stereo Integrity BM MK5 subs
3 x Mosconi Zero 3 for front stage
Mosconi Zero 1 for sub duty
I didn’t tune it, but the speakers are getting every bit of power they can take while staying in balance with the weakest link. Theoretical maximum output from each Zero 3 is 270 watts rms per channel at 4 ohms. Given the Morels I used are 6 ohm that reduces the output of the amp to 190 watts or so per channel. Obviously they are turned down substantially from the maximum. I think the Dynaudio E650s are getting the full dose. And I am confident the subs are at their limit just running in stereo off of the Zero 1 with somewhere between 450 and 650 watts rms each.
I’m confident that nothing I added causes the hiss because as soon as you unplug the factory source the hiss goes away.
Where are u taking the factory signal from? High level or low level?
Ur right on there where do u stop bit, with my loud injectors intercooler pumps etc chasing hiss seems a little daft
