GT350R Springs for GT (high rate, minimum lowering)
Rocketman
Keep it stupid, stupid
2017 GT PPPPPPP
Can the GT350R front and rear springs be run on the stock PP dampers? I know it's been stated that it is not recommended but would it actually work?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Yes but it will be pretty uncontrolled and bouncy.
Niz55
Us
17 GT350
So if I install the R springs on my 350 it will raise the front end little bit correct?
BmacIL
Enginerd
Naperville, IL
No, R sits lower than the normal GT350.
BmacIL
Enginerd
Naperville, IL
I thought it was due to the tire side walls bring lower.
It's both. The front of the R sits approx 1" lower than the GT350, half from the tire sidewall, half from the springs.
EFI
Masshole central
5.Br0
Can anyone confirm the exact part numbers for the R springs? There's a bunch of different ones and prices, none ending in M however. And the rears don't differentiate between left and right.
BmacIL
Enginerd
Naperville, IL
Front: FR3Z5310M
Rear Left: FR3Z5560T (Now X Suffix)
These are the ones.
Food for thought: the BMR SP083 (rev C) handling springs are about the same price for a set of four. The rates are very similar, with a tad more drop. They used to be further apart in those attributes but with the Rev C, they're a great choice for handling rates without too much lowering. The R springs are also amazing.
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
The R springs are amazing and when mated up with the Steeda Pro-Action fixed dampers it's awesome.
Myshelby3425
Miami
2018 GT
Bmacil what rear springs do you recommend if I’m going with R springs and steeda fixed shocks if I’m running the R front 34mm sway and rear R 24mm sway?
BmacIL
Enginerd
Naperville, IL
Probably R rears also. FR3Z-5560-X (or FR3Z-5560-T).
BmacIL
Enginerd
Naperville, IL
Would the sp088 rear be too soft?
IMO yes. The car would understeer. If you're not tracking it, then it'd be fine and would ride quite nice, though.
Edit: wait, you have a GT350? If so, you need the left and right rear springs, not just two of the lefts. Right side is FR3Z-5560-W (or FR3Z-5560-P). SP088 would not work, but talk with Kelly [MENTION=9985]BMR Tech[/MENTION] about his Magneride springs. Even if you don't have Magneride they'd be excellent. Give him a call.
Myshelby3425
Miami
2018 GT
Yea no tracking. It’s a daily with occasional drag days. I only get brave on curves when coming on and off the expressway, lol.
