GT350 vs. Z/28
Status
Not open for further replies.
flaps
2019 WRX
Some magazines had actually tested a GTPP just as fast as a C7 Z51 at the same track. It's not a great example BUT, never has a GT put up compatible lap times to a Corvette.
Source? I don't remember seeing any magazine tests that had a GTPP being just as fast as a C7 Z51 at any track.
Cashcow
AMG GT S, S550, Camaro
I'm specifically referring to a DOHC 5.5 v8 they had developed. But it didn't make the power they needed. Was intended to go into the corvette.
I'm pretty sure the motor made the power they wanted they just couldn't get it to meet the fuel efficiency needed.
thePill
thePill
Camaro5's Most Wanted
Pittsburgh
S550
Because you didn't look... The GTPP matched the C7 Z51's lap time... Oh no!!! That means the GTPP is just as fast as the Z51 :lol:
Oh the humanity!!!
thePill
thePill
Pittsburgh
S550
Actually, I heard it was detonated because it was too nasty for the environment.
Definitely not a fuel efficiency issue. An OHC design naturally saves fuel unless GM found a way to fowl that up too.
They spent $820,000,000 on LT R&D. The cost to engineer a V8 OHC now would be 3 times that amount. They should have started in the 90's like Ford. It was cheaper then and they have 20 years experience in Modular Engine design.
The $820m alone is enough to stuff an OHC program. They would have almost $3 billion dollars into V8 developement all at once. One thing is for sure... they need to think of something. The OHV will be obsolete in a few years at the OEM level.
9secondko
Irvine, ca
2003 cobra
It wasn't just fuel efficiency. It was emissions.
That's my point. Anybody be can dirty power.
But the power needed from GMs DOHC v8 that could actually legally be put into a mass market vehicle was sorely lacking.
In other words, as I said before, they couldn't make the power they needed with it. So it got the boot.
thePill
thePill
Pittsburgh
S550
Haven't you read, he like to make up numbers.
http://fastestlaps.com/tracks/willow-springs-streets-of-willow
So? Is this a misprint or was there some crazy circumstances the Z51 needed to go through? Rain maybe? Different driver and different day? Although that never matters anywhere else... The GT was a 2015 and the Corvettes were older. Probably not fair then? Maybe I'm making this up...
I find it hilarious that this happened... The mighty 1LE is faster than the Stingray too!!!! Truly a feat worth mentioning...
According to that list, the GTPP nearly lapped Willow faster than a Pre-2012 Z06/Z07 too.
Made up???
mustangletback
chicago
1990 droptop mustang
Made up???
keep killing them with the facts.:popcorn:
:lol:
02gtnh
Nh
16 corvette conv. 17 F150
Made up???
Be real. Your comparing time run by Probst in the GTPP to a no name driver in the Stingray.:crazy: you would have to be the blindest fanboy to think a GTPP and 1le would beat a Stingray with equal driver.
thePill
thePill
Pittsburgh
S550
That is real and this could happen in real life as well...
The Mustang and Corvette are getting closer together. Soon there will be no room for a Camaro comparison without a Corvette as well.
Be real... that was a fully loaded GTPP Premium... It's not the standard we are looking for. It's a good indication of what a GT can easily do but not the whole story.
SidewaysPete
Cali
2015 Mustang 5.0, 2014 5.0
Made up???
Hahaha you're a god damn clown. You cherry pick what information you use to try and validate your fallacious claims.
How convenient he uses that to prove his point, but if you point out that the 1LE is significantly faster than the GTPP on the same link he provided, he will deny it and make up some conspiracy theory as to why that is. Both cars driven by Pobst, and the 1LE lays the smack down. Not to mention the stingray has no documented driver. Hahahaha!!
This forum is pretty sad for buying into this guy's fabricated stories and conspiracy theories.
As for the z28 vs GT350, it looks like the GT350 is significantly slower than the z28 if you watch some of those hot laps done at laguna seca. I'm seeing around ~1:41 laps for the non-R. Prepare for a massive let down, ford fanboys. The mighty GT350R might BARELY beat the z28. history is destined to repeat itself ala s550 GTPP vs 1LE.
Status
