GPF/OPF removal on 2018+ 5.0
emix
Bucharest
Mustang GT manual LB
Hello, has anyone found a reliable solution to remove the particulate filter on the facelifted cars? Any pointers are appreciated. Thanks.
Badmanners
Sweden
Corvette c7 z51, Dodge ram srt10 rc
Thats no problem at all.
cib24
UK
1999 Mazda RX-7 Type RS
You can buy cat deletes and cut it out and weld the cat deletes in but then you will have error codes and the engine might run in limp mode. Plus, you will be polluting to high heaven.
But you can do it and then tune for it to remove the error codes and extract probably 15hp and 20 lb/ft of torque in the mid range.
Or just buy shorter gearing like 4.09s and be quicker without doing all of that l, and enjoying the car more because the gearing is no longer intergalactic.
Badmanners
Sweden
NO he cant because of The GPF Filters. He is not talking abot removing The converters, in The EU spec cars we have gpf built in with The converters and a bunch of extra sensors etc
cib24
UK
Yes, he can. I know they are all one unit. You can technically remove them but without a remap to block the sensors and error codes, the car won't run right.
