Glovebox light removal led replacement
Beachfun
UK South Coast
Airbus A380
OK I have found the secret to the glovebox light removal
Open the secret compartment - This gives you a bit more room
The light assembly pushes up just a little about 6mm at first I did not know that it had moved up until I tried pushing it down and it clicked back into place!
Having moved the light assembly up it still would not come out! The big secret is ... You need to push the on/off button in to turn the light off and then is will wriggle out easily!!
Disconnect it and you can safely remove and replace with your led without the risk of fusing!
If you already blew the fuse it's a small 10amp number 1 in the foot well I believe (I did not need this just read it somewhere!)
Cati
U.k. Down sarf
2015 get v8 ucl mag grey & e93 m3 cp
do you get out much?
Beachfun
Beachfun
UK South Coast
Airbus A380
Just trying to help
The second word is OFF you choose the first word to go with it! Lol
Cati
U.k. Down sarf
Because my sarcasm filter was turned off :eyebulge:
Sixth
A
Prius
The way I did it was open the secret compartment, then you can fit some needle nose pliers in there and pull it out. Also be careful with orientation. Putting them in wrong and trying to force it on makes you blow fuses...haha
