FMJ
This listing is for the pair, you get both the left and right light.
Lenses are in very good condition with no cracks, chips or obvious scratches.
Genuine Ford Euro clear lens tail lights with Genuine USA Ford internals.
Outwardly these lights are European but the internal LED boards have been swapped to with a set from a pair of USDM red tail lights. The wiring and plug has also been swapped to USDM. So you can simply unbolt the three bolts holding your red USDM tail light in and unplug it. Swap this light in and it will still function and light up exactly the same as your original USDM lights but with the clear Euro lens.
All original Ford parts used in the swap. No cheap additional non Genuine LED boards.
As far as I am aware you can’t buy these anywhere online and instead have to mess around changing LEDs and wiring/plugs etc to get them to work. Or buy lower quality none genuine lights. This set is simply plug and play with Genuine Ford quality.
To perform this modification the lights have been opened and resealed. You will notice a seam of black adhesive is present. The adhesive used it very high quality (used to attach body parts) and forms a strong water tight seal. You cannot see any of the adhesive once the lights are fitted.
Please note all LED tail lamps in certain conditions will fog with a small amount of moisture (this is referenced in the cars owners manual). These will be no different but I assure you are just as water tight as the originals.
These are aimed at US owners due to being compatible with their cars.
Postage from the U.K. to USA is expensive so sorry about that.
I would like $400 for the pair plus $80 shipping from the U.K.
Cheers.
Cheers.
