Gaskets needed for OPD/CSG install
Ggradtech
AZ
Can anyone give me a list of gaskets/O-rings needed when changing the OPG and CSS on a 2016 Mustang GT? Im pretty sure the valve cover ones can be reused. Thanks!!!
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
You can completely reuse all gaskets and o-rings. Unless you damage them from removal, and that is very doubtful, that would only be the reason to get a replacement. Most commonly people buy a new a/c belt to replace the stock one as it's just easier to cut the current one off. You'll also want an MMR damper install bolt (or all thread equivalent and bolt) and some Ford TA30 silicone or aftermarket equivalent.
dsp4848
Hutto, Texas
David
2015 GT PP Magnetic
Yep, pretty much this. I bought a new front cover crankshaft seal, thermostat housing o-ring, and new front cover gaskets just in case, but ended up using the stock ones. I did buy a coolant pump o-ring and replaced it just in case, but honestly you probably don't need to. The stock valve cover gaskets are actually really good, just make sure you don't use metal to scrape off the old gasket sealant - use a plastic piece. I did buy and use the new OEM AC belt. It was easy to just cut off the old one and install a new one.
Other than that I bought an OEM Ford crank bolt and washer and some Permatex Ultra Black gasket sealant and it worked out great.
Crackerjack17
WV/Maryland
2017 GT PP
I guess it depends on how old and how many miles are on your car. Mine was new with only 4000 miles so I didn't need any gaskets. They are very thick chunks of rubber not some little thin gaskets. Easily reusable. I did buy the ford recommend rtv that gets used where the case halves come together, but imho don't need it. If I did it again I would just use good quality black rtv.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
I contacted a couple forum vendors on here who do these installs all the time, and they said they also reuse the stock gaskets if they are un damaged when removed. These cars typically don't have engough miles and wear on these item to warrant replacement at this point.
Mod Mustang Racing
California
www.modularmotorsportsracing.com
Worlds Fastest & Only 5 second Coyote
