Fusible Link for alternator
donmcgowen
Chicago
2015 Mustang GT, D1 Procharger Stage 2
2015 Mustang GT ON3 61mm twin kit charging system light is on.
I had an issue with the power cable going to my alternator. I had to add an extension because of turbos. Anyway, the cable pulled off the alternator doing a pull. Brought it home put it on the lift and found the problem. Like a dumbass, I tried to reconnect it and ended up shorting the cable.
The problem is I don't know where the fusible link is. Does anybody know where the fusible link it? In older cars they were an extension to the battery cable that would break and you had to replace the cable. But this car it might be one of the bigger fuses in fuse box. But I checked all the fuses and they all look good.
