Fuel System Related Questions
KPM Fuel Systems
Adelaide
David
FN Mustang
To help be more involved in this community, we would like to offer our experience on this topic and open the floor to all questions you have regarding Fuel Systems.
Hit us with your questions and we will endeavor to do our best answer them!
Fire away!
wingnutt
@FL410
michael
350R Procharged w/P1X
subscribed for future use 😎
19BULLITTwhipple
California
Ramzi
Bullitt 2019
I have a question!
My car started yesterday just fine.
Today it only cranks and will not start, no other changes.
So I took off the line connecting the filter and primed the fuel system, And fuel came rushing out into a bucket. .
My question is would a dead fuel pump cause the car not to start? All the plugs are in and I think the car is getting spark. And it has plenty of fuel, 10 gallons today.
Fore triple 274 pumps, -10 feed and -8 return and the the feed line goes to a Y block feeds both rails independently and returns to the regulator.
Any idea? Or is more information needed to diagnose? Also jumped the FPDM and still did not start. No Fuel Leaks. Not noticeable vacuum leaks
KPM Fuel Systems
KPM Fuel Systems
Adelaide
David
FN Mustang
I have a question!
Due to you having a 3 pump system, 1 dead pump would be unlikely to cause a no start.
You can check if you have fuel flow by disconnecting the return line from the fuel pressure regulator and crank.
Any sufficient flow should at least cause the engine to try and fire and try to run.
We would not try to start and diagnose remotely as the possible causes of a no start are numerous.
CameronPierce
AU
Cameron
020 Mustang
Replying here so that I can keep track of this thread.
KPM Fuel Systems
KPM Fuel Systems
Adelaide
David
FN Mustang
Question for those that take their Mustangs on track.
Do you have fuel starvation issues??
Especially on cornering
Especially with half a tank of fuel or less.
