Fuel gauge not working
hurricane1091
2015 Mustang
Hello,
So, my fuel gauge shows E. But it's not E. What gives?
Glenn G
Kaiserslautern, Germany
Glenn
15 DIB 6MT base Ecoboost
Did you drive it down to empty when it happened, I've seen this usually on older cars where the arm gets stuck on the bottom. solution is usually to have only around 1/4 tank, find an empty parking lost and get some g's to either side to get it loose. Otherwise just go to the dealer as it could be the sensor, Sending unit or just the gauge motor. all a PITA to fix yourself, Just take it to the dealer as close to empty as you can, if he has to drain your tank, you will probably loose whatever you have in there, (which will probably end up as a free gas for the mechanic who is working on it)
hurricane1091
2015 Mustang
I don't usually get too low. I had a problem with it a couple of weeks ago. But then it was fine and I went on vacation and left my car behind. It's back though.
Now, this should be covered on the warranty I imagine? I'm at like half a tank at the moment (I estimate).
I had to hit the brakes pretty hard a few weeks ago. I wasn't driving too fast or anything, just traffic happened and person in front of me hit the brakes quick too. I didn't have any problems then though or for at least a few days.
jbailer
Joe
Try disconnecting the negative terminal of the battery for about 10 secs and then reconnecting.
Neko-
Netherlands
2019 Mustang EB
Might be an old thread, but I'd like to thank @jbailer for the suggestion.
Audio acted up after the car had been at the shop. Sounded metallic at certain frequencies. Figured I might aswell pull the battery for a minute or so to see if that fixes anything.
Yes, it did seemingly fix that issue (didn't stick around with the car long enough afterwards to really test that but it sounds way better again). But the fuel gauge went to empty and remained there. Computer complaining about 10 miles to empty and the like... While I _know_ I got a bit less than half a tank in there. Bit of driving didn't do anything, and only once I pulled the negative terminal for some 10 seconds like @jbailer suggested and reconnected... Bam. Gauge started working again.
And knock on wood - the audio also sounds like it's behaving again.
SheepDog
Colorado
Dax
What does a gallon of gas cost in the Netherlands right now?
Neko-
Netherlands
2019 Mustang EB
Seeing that would go offtopic... I'll toss it in a DM :)
