Fuel Drain - What Are You Guys Using?
Chummel
Tulsa, Ok
2015 Mustang GT PP
Yep. Fuel drain tune. Your tuner can make you one.
When swapping back to your normal tune, do you need to worry about the pumps running dry? Because when you power your car up won’t the pumps kick on due to the previous tune?
dubster99
Nor*Cal
2015 Ingot Silver GT PP
Once you start overwriting the tune it shuts the pumps off.
Chummel
Tulsa, Ok
2015 Mustang GT PP
I assume it’s okay for the pumps to run dry for those few seconds then?
dubster99
Nor*Cal
venumous
PA
16' Procharged GT
You can also run a jumper on your fuel relays if you have a return system.
