FRTP sway bar setup
dmann
Alabama
2018 GT PP1
I had this suspension installed and am fairly happy with it for street manners. I will track it alot in the fall but have some questions.
The car feels a little loose in the rear in turns while the front feels hooked up. The installer said he set the front sway bar to the soft setting and the rear to the stiff setting, could this be the loose feeling i get in the rear now? Maybe set the rear to the soft setting and test?
dmann
Alabama
2018 GT PP1
should they typically be set similar front and rear or is it good practice for the rear to be a little soft?
Bluemustang
2015 Mustang Base GT
Yes, absolutely. The stiff rear bar is generally not something that works in this car, at least that's been my experience thus far.
If going to stiffen one end, stiffen the front instead where it's needed.
strengthrehab
Houston
Ken
2016 DIB Base GT with PP
I went from a Pedders rear bar to a stock GTPP bar when I installed my rear lower control arm bearings and the difference is amazing. I can actually power out of corners now with only very predictable oversteer.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Reverse that. Installer doesn't know what he's doing.
Grintch
Hunstville
2015 GT PP
Soft front and stiff rear is the most loose/oversteery setting you can use.
I currently run Stiff/medium, but it's a little too pushy for my staggered Michelin's. But I think it should be about right when I run the square NT-01 setup.
strengthrehab
Houston
Ken
My I had medium/medium (I forget the rates) and it felt good, but I had too much oversteer on corner exit. Now I'm at middle front/stock GTPP rear and feels so planted with the square NT01 (305) setup.
dmann
Alabama
2018 GT PP1
all this makes perfect sense with how the car feels, much appreciated guys!
Grintch
Hunstville
2015 GT PP
You running the FPTP bars? IIRC the front bars are only two position, soft or stiff. With three position rear bars. I know some of the aftermarket options are 3 position front AND rear.
I am also running the FPTP springs (like Dman), if you are running different springs or coilovers that may change the balance (and the best ARB settings).
dmann
Alabama
2018 GT PP1
I was just about to ask you that. So, the FRTP has two setting up front and three in the rear, check!
Is my logic correct in thinking the ends of the SBs are the softest settings?
strengthrehab
Houston
Ken
I am not running those bars. My comment was more aligning the "rear setting should be soft vs stiff" argument
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Your installer is trying to kill you :p
Run the rear bar on a softer setting, the car will oversteer less easily and should feel a lot more planted. If you want more rear grip, soften the rear bar. If you want more front grip, soften the front bar.
Only go as stiff as you need to meet your goals for flat handling and weight transfer speed. Softer means more grip in general.
