Front suspension clunking
shadowx
Missouri
mustang gt premium 2019
Clocked bushings and everything seems tight enough and still got the same noise
shadowx
Missouri
have you done any suspension mods recently?
My bad I didn't mention here what I have done.
I got FRPP with BMR handling springs, BMR caster camber plates. BMR swaybars with Steeda endlink
Twi5ter.0range
somewhere
2020 GT Premium, 2023 Ecoboost Premium.
It could be the bolt that holds the strut mount to the shaft cause when you tighten it, it spins the shaft as well so you would have to hold the shaft with some vise grip pliers.but your camber plate is your strut mount now and the same thing applies. could be the 3 bolts on the camber plate up top not being tight enough.
Twi5ter.0range
somewhere
tbh it could be a bunch of other things. i would retighten every bolt and nut that was taken out. i like torquing down suspension components so i don’t hear any clunking noise and it’s just a peace of mind but others will say you don’t need to torque it down
shadowx
Missouri
Would check this and see if it's the issue.
