Front Strut Shaft Nut Torque
Burgo
Australia
Keith
2017 Mustang GT 5.0L, 2014 FPV F6
Can anyone tell me the torque for the front suspension strut shaft nut torque please?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
76 ft lbs per the shop manual.
Burgo
Burgo
Australia
Keith
Thanks buddy, if the strut is still in the car can this nut be safely removed without having to compress the spring?
BmacIL
Enginerd
Naperville, IL
I wouldn't, it's not safe, even though I know some have. Why do you need to remove it?
Burgo
Burgo
Australia
Keith
It's worked loose and the strut is knocking, so my thinking was to replace it with a new nyloc nut.
I can see why you shouldn't remove that nut without a spring compressor when the strut is out of the car but when it's still in the car the spring is compressed, I can tell there isn't any load on it as I can nearly turn it with my fingers.
BmacIL
Enginerd
Naperville, IL
Just not a good idea. Chances of anything happening is very low but it's not a good idea to leave that under compression without something. You can probably just tighten it rather than replace it. I had to do that within a couple months of my first suspension install and it remained tight for 2.5 years.
Burgo
Burgo
Australia
Keith
I can confirm that the nut will come off safely whilst the strut is still on the car, I chucked some Loctite on it and torqued it back up. I couldn't put a new nut on as the dealer didn't have one in stock.
