Fitment? Forgestar F14
aaronbreid
I've been offered a great deal on Foregestar F14's, but I'm not sure they will fit my '16 GT Base.
HUB: 72.56
Holes: 5
S.O.: 20
Offset: 20
P.C.D.: 120
I believe I need a 5mm spacer for the fronts, but any additional info would be helpful!
ZenkaiRacer
Utah
2015 GT M6 Supercharged
I believe with that offset it will poke a significant amount. So no you wouldnt need the spacer.
In my opinion that is too much poke. I think you'd need some crazy camber to get that under the wheel well.
Shouldhavegotthegt
Phoenix
2016 Magnetic GT 2014 Ram 1500 RCSB 4x4
They’ll fit. I’ve got 20x10 with a 45 offset and 20mm spacers so basically a 25 and there is still some room. No poke but just about flush. I’m running 275/35 tires. Probably couldn’t go much wider than 285 though.
BenM
Canberra, Australia
Ben
Magnetic GT.
[MENTION=33609]aaronbreid[/MENTION].
Critical spec: PCD doesn't look correct. It should be 5 x 114.3.
Might want to check this.
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
HUB: 72.56
Holes: 5
S.O.: 20
Offset: 20
P.C.D.: 120
The offset is aggressive by 15 mm
Also bolt pattern is wrong our car uses a 5x114.3 also known as 5x4.5
5x120 is for a bmw
