first time out, how did I do?
tyguy
illinois
2016 gt
Well last Friday I finally got some good weather to hit the track with the new car. I just did the first oil change at 2k and decided I was ready to see what I could do with it.
I'm not sure what the da was that you guys always talk about but the humidity was maybe 50% and around 80 degrees, about as pleasant as you can get for July in illiniois
I have a bone stock 2016 gt auto with 3:15s, surprisingly I had no trouble hooking up with the stock 235s. So I didn't hardly heat the tires nor drop pressure.
Awhile back most guys told me to just put it in drive and foot brake at 1500 or until it started pushing the car. However, after several confirmed passes, I ran good tenth quicker just by having it in S mode instead. Has anyone else had the same luck?? Anyways here's my best run listed below. I was fairly happy with it compared to what other guys are running bone stock.
Jay-rod427
Kansas
2016 GT C/S
Not too shabby. I would put it in Sport mode via the switches, and not the shifter tho if you have a premium.
That probably gets you into the 12's in the 1/4. Expect some significant gains when the weather cools down, and dries out.
Hyland33
Leicester MA
2016 GT/CS
This was from my first event. Stock auto/3.55's. Put shifter in S, foot braked to around 1800. DA was 2200. Car wheel hopped 1-3 times every pass and then hooked and took off.
tyguy
tyguy
illinois
2016 gt
yea i just have the base model so no toggles.
Thats a dang good pass, my 60ft matches but im guess the better air maybe got you quicker et?
LETHAL
From the D but in the NC
Asheville, NC
Kevin
2018 GT A10
Decent 60 ft.
Mine with just a Steeda on a freak 75* feb day pulled a 8.6 @88mph with a 2.1 60ft.
With the Corsa and Lund tune added since, at Bristol with DA in the 5700 range it ran a 13.3 [MENTION=17112]10[/MENTION]6 with 2.2 60s. MEHHH but that air was pure soup. DA corrected says 12.3@114.
