First service with a modified car
wuzie123
Ellon
Doug
Anyone had any issues with getting their first year service done with a modified car?
Eclipsar
UK
NFG Mustang GT
Mine went through with no problems, coming for it’s second service soon
Enoch
UK
Andy
Guard 5.0 (Auto) Fastback, Saddle Leather
All I did with mine is put the stock tune back in, just in case they flash the ECU with an update:)
Other than that I got a full service report that mentioned aftermarket rear brakes, but still gave me the pad thicknesses on the report..
Nothing else was mentioned.. I took my own oil and filter, and the service was ÂŁ133 quid at my local Ford Store:):thumbsup:
Dinks66
Chorley Lancs UK
2017 GT PP Lightning Blue. Borla S- type cat back
Just had mine done last week at Bristol St Bolton. Flashed my ECU back to stock prior to taking it in and fitted an insert into my CAI so it would run ok and it went through no bother. Had it back in less than 5 hours. ÂŁ250 with courtesy car. That was with suspension, wheels and exhaust non standard.
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
I've had mine serviced twice, both modded, once with tune, once without.
All I noticed had been done on this servo this year was coolant was drained and replaced, oil changed and replaced, brakes and visual inspection (via video proof), tyre depth, usual check stuff, and then they've put Vaseline all over the hood latch.
SteveS
...Bon Scott Land...
Bon Scott Land
Mustang GT Magnetic
Had mine serviced a couple of weeks ago in Perth, it's second service. Took about three hours as the service admin explained "they hadn't done many second services on these things" :eek:
They asked if it had had its springs done...you'd think they'd know...as one wasn't seated correctly. Didn't offer to fix it and I didn't push them on that as it shouldn't be covered by warranty. Had the issue resolved locally by a place i'd highly recommend.
No issues caused by modifications on either service though.
marks
Essex
2017 Mustang GT Race Red Manual
Not really a service issue but more MOT - when it eventually comes to it in a few years. I'm not that au fait with exhausts, so if I need to change back to the standard exhaust during an MOT - can this be done fairly easily with a cat back (as I understand you don't have to cut anything, like with an axle back)? Thanks
tj@steeda
Timothy
wuzie123
wuzie123
Ellon
Doug
Ok think I will put the insert in and re-flash the ECU back to stock... im running the Lund tune and Ngauge. if they flash the ECU will that mess up the link to the ECU as in will i need to "re-marry" the unit to the ECU?
Thanks for the reply's.
Manders Mustang
The Boss
I did totally forget this on my second servo (last week), and they didn't flash anything, and the tune is still fine cobb AP is still married, no divorces occurred. :thumbsup:
Jimboy2
Denmead, Waterlooville
Mazda Mx5 :(
As long as it passes emissions and it isn’t “modified” you will have no issues with exhaust. No need to change it.
marks
Essex
Thanks but just in case, can I change it back easily?
Manders Mustang
The Boss
yeah remove bolts from cat side and slide it out in 1 piece :p!
