Fic 1000s enough for f1a94?
Jaywebs
Jason
2019 mustang gt. 2019 c7 z06. 2019 rs5
Hey all. Upgraded from a p1x to f1a94 and are acquiring additional parts for the swap. I have a Fore triple pump return fuel system nwhich will obviously feed enough fuel, however I currently have fic 1000's. Does anyone know what injector I should go with moving foward. Also curious if anyone knows what these injectors are rated for. Tia
illtal
How much HP and what fuel....
What generation Mustang?
You can have the boost turned down and still run 1000s
If you are gen1/2 ID1300x FIC1440 may be the largest you can run and have idle properly on pump gas
Gen3 can run FIC 1650s and ID 1700x these two can get you around 1300 wheel on gen 3
Jaywebs
Jaywebs
Jason
Gen3 Sealed motor as of now so would like to keep around 1000wheel. Running e85
Jaywebs
Jaywebs
Jason
If your not sure what "sealed" means, Im not sure your the guy to correctly answer my question.
illtal
No dude people say things they don't really mean all the time. If you want you can explain what you mean or not . You have your answer.
The reason I know this is because I just went through this myself sizing injectors. Currently I have dw95s in my current set-up
Jaywebs
Jaywebs
Jason
So "sealed engine" would be slang for a unopened stock engine.
illtal
I thought it meant something else.
Like the nhra sealed engines meant for certain class racing.
Either way same deal a stock engine. At that power I'd look at getting a short block together. These pistons don't last at that power.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
I would run ID1300/1700's if you're planning on going over 1100whp..... 1700's will support between 1300-1600whp.
illtal
He ain't going over 1000 with that stock engine
RagmopInKona
CEO
2020 Mustang HHP
No it is not.
Sealed motor,engine is race series units the teams can not open and touch under the rules. If they do they get fined or tossed for the season.
Slang for stock is not "sealed"
Jaywebs
Jaywebs
Jason
I am definetly going to try. I think Turnswrench made 1200 or something crazy on a factory motor. The question is how long will it last.
Jaywebs
Jaywebs
Jason
I stand corrected. So myself and 98% of the other people on this forum have using this terminology incorrectly. Thank you for clarifying.
