Factory Brembo Rotors and Pads?
2015Etrac
PA
Black 2016 Mustang GT Premium 401a
How are the Performance Pack factory pads and rotors? I bought them to install with a pair of Brembo calipers I also bought to upgrade my stock GT 4 piston brakes. Should I have went with an aftermarket pad/rotor setup? It will be a daily driver 99.99% of the time, but can they handle an occasional autocross or track day?
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Top question - do you have base-GT design rotors (air is drawn from the wheel side, not so good for shedding heat) or PP rotors (back side air inlet)?
Norm
wmfateam
Arizona
www.facebook.com
Whitey
2017 LB GT PP
I have tracked and weekend(7k total miles) the factory GT Performance Pack brakes all year(11 events so far) and still have a little life left. I am swapping out another set of stock pads before my last two events.
2015Etrac
2015Etrac
PA
Norm
Right now I have the stock 4 piston GT calipers and the 14" stock rotors with the front vent. For the upgrade I bought the stock 15" rotors with the rear vent from the Performance Pack cars.
2015Etrac
2015Etrac
PA
Thank's. Was hoping to hear that since I already bought the pads. I didn't want to run anything that would be noisy on the street.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Pads are great for the street, autox, and semi-OK for moderate track day use. If the driver or track are hard on the brakes, you can definitely fade and glaze the stock pads, but it takes some effort to do so.
Stock pads are kinda dusty FWIW. Some of the aftermarket pads are a bit better at low dust.
Rotors are good to go, no issues.
Norm Peterson
Norm
'08 GT #85, '19 WRX
Stock PP rotors . . . you'll be fine.
Norm
2015Etrac
2015Etrac
PA
Just picked up my rotors today, do they make these thing out of lead?! I kind of wish I went for a lighter 2 piece set. haha How much difference do lighter rotors really make in acceleration?
Norm Peterson
Norm
'08 GT #85, '19 WRX
Not nearly as much as most people want to believe. Keep in mind that all this weight is all at relatively small radii from the axle center, and is being accelerated (rotationally) at the slowest rate in the entire drivetrain due to overall gearing. I ran some comparative numbers once, and I think it worked out to where 5 lbs/rotor times 4 was about the same as 30 lbs worth of barbell plates inside the car itself. Call it 40 lbs if you want to be 'conservative' in your estimate.
Norm
Labradog
Santa Barbara, CA
Jeff
2016 Mustang GT Guard Metallic
I went from Base GT 4 piston to Brembo + Steeda 2-piece rotors and I think lost 4-5 lbs per corner. Weight difference not really noticeable to me, at least with my street driving. I bought these cause I didn't want to look at rusty rotors and with my yearly mileage they're gonna be on the car a long time.
cmorrigo
Rancho Mission Viejo
2016 Ruby Red Mustang GT
I just bought a used set of Brembos from Shelby to put on my 2016 base GT. Any words of wisdom regarding installation and additional parts required? Thank you, Craig
2015Etrac
2015Etrac
PA
I don't have mine installed yet, but you'll want to look into the performance pack dust shields and front brake hardware kit (if it doesn't come with them), I bought the pins and clips for both sides for $17.99 from Optimum Performance. Other than that, just rotors, calipers, and pads. It should bolt right up. You can use the existing brake hoses and caliper mounting bolts. The most difficult part for me will be bleeding the brakes. There are a few install videos on Youtube.
Norm Peterson
Norm
'08 GT #85, '19 WRX
Anybody who can follow directions about when to push the brake pedal down, hold it, and release it is really all you need. I've enlisted help from various family members (like, whoever was available at the moment). Son-in-law has had his daughter working the brake pedal when she was 12.
Norm
wildcatgoal
@sirboom_photography
TBD
Factory pads are fine, even for a beginner on track day. Factory rotors are all that I use (until I can afford 2-piece fancy pants rotors). I have cracked (albeit very minor) aftermarket rotors from Powerstop in one Road Atlanta track day.
FISH_L3G
Dallas Texas
Jeff
2015 Mustang GT pp in Competition Orange, 86 Corvette, 2012 Honda Civic
Hey guys, I recently purchased a 2015 GT with the PP, car runs well but the dang Brembos on this thing squeak like there is no tomorrow. I have pulled the wheels and checked the pads and calipers and they have ample life left in them and was able to confirm they are original to the car as it has relatively low miles (30,000). I spoke with my service advisor that I actually trust and have a good relationship with over the years and he stated that is a common complaint with the PP Brembos. What have yall done to get these dang breaks to stop squeaking? i have also tried
