Angrey
- Jun 21, 2020
- Coral Gables
- 2016 GT350
It's just different strategies. The electronic regulator (with return style) doesn't need to anticipate because it has capacity in reserve. The whole point of variable control is to economize the fuel pump consumption/draw and reduce electric load and not put more heat into the fuel than necessary. The return style system accomplishes this in a slightly less than optimal way by sending a portion of the fuel back to the tank (in reserve). The PCM "approximation" has to anticipate any rapid changes in demand and the only way it can do that in large power applications is to run the pumps at higher output than is currently necessary, and even then, the lag from when it wakes up to when the additional flow is at the rails is what drives many tuners to just go return style.The great thing about the PCM logic is that it knows the fuel demand BEFORE the engine actually needs it. An external regulator can never know what's about to happen like the PCM does. The PCM knows the future airflow and future fuel flow before it happens because the PCM is controlling both. As such, it can send the appropriate voltage to the pump before it needs the extra flow. That's the genius of the Ford DBW system and the Feed-Forward controls. It already knows how much to open the throttle, where to send the cams, how long to leave the injectors open, what spark timing to send, etc because it is all modelled before the state-change. An external regulator has no predictive ability and can only react to changes after they happen.
Would be an interesting study to see overall which one manages the pumps/draw more economically. In any case, the part you didn't address is that I can mechanically/physically install my setup and away we go. Yours has to be tuned by someone with time, skill and experience and then revised/updated to account for any gaps or inaccuracies in the tables. You have to remember, not everyone is as smart or dedicated as you. For most people, simplifying this system is a win-win and fool proof (while eliminating the returnless lag issue, economizing the fuel pump loading, etc).
My setup simply rolls up the windows when it starts to rain. Your approach has to draw on schedules and information from weather data and pressures and light levels, etc to try to "infer" when it's going to rain. Can you get to the same outcome? Sure, but I walk up one block and you have to walk 5 blocks over 3 blocks up, 5 blocks back and 2 blocks rearward to arrive at the same place.
