Engine tweaked during a pull
Frogger
Spring texas
FR IC JLT CAI ATP DP Meth INJ Cobb Tune FR ABs
Coming home, I do a decent pull, revving to about 6K between gears. Then my engine starts sputtering and wont accelerate. I coast into a parking lot. Restart my car. Now it runs fine except it makes a strange whirring sound that is synched with the engine rpms.
Dannyho
Connecticut
2015 Ecoboost Premium PP DIB
Check to see if one of the charge pipes popped off. People have reported issues of that or them being loose.
Nihil
Cowabunga
Roanoke, VA
Grey Goop
yup sounds like a charge pipe flew off, that's the sound of your turbo blowing out air and/or air being sucked into the open pipe to feed the engine
LeonBorden
Florence AL
2JZ Formula D Pro AM Cressida, 2015 EB PP
It's probably the hot side. Passenger side. Most likely where the plastic pipe goes to the rubber coupler down low.
Frogger
Spring texas
Thanks guys. would that have caused what I described before I turned off the car? then corrected afterward except for the whirring. Is it safe to drive a bit before fixing?
LeonBorden
Florence AL
No, unfiltered air is directly entering your engine.
Frogger
Spring texas
Thought I checked the pipes and hoses pretty good but it was a little dark. Here's another sound clip to see if you all can verify the sounds. The audio is better than last.
Anthony@HTM
SF
GT350 Track Pack
Oh that doesn't sound too good.
Although I don't want to be the internet mechanic, it sounds like something is disconnected or interfering with eachother
nadojay
Cairns
2014 SRT Grand Cherokee
damn hope you find out whats up, sounds like my electric rc car
dragonacc
TN
2015 Ecoboost PP
Not sure what that is. Hope everything is alright though!
Frogger
Spring texas
Took it to my mechanic yesterday morning. He was getting an error code regarding the throttle body, which he thinks is consistent with my mods and not having the proper tune. After he blew the code, it still whirs a little. Taking it to the dealership hopefully tomorrow.
Frogger
Spring texas
Also, I noticed today my temps are running high. When I'm idling they crawl up, see pic, when I drive they go down.
