Vietzboi87
- Aug 3, 2015
- South Florida
- 2015 mustang gt
Thanks for the great info! I might order the sportlines since they're only $218 shipped.
Excellent information hereFWIW, I got too excited about buying parts last Thanksgiving, and after the fact felt that I didn't do enough research with some of my purchases. I hadn't had a Mustang in 13 years (Fox with all the bolt-ons), and bought one of the first of the 2016's, and immediately got all mod-happy. Specific to springs, I got a great deal on Eibach Sportlines, but later on did some research in the forum and came up with two main issues: S550 works better with linear rather than progressive springs, and going much heavier in spring rate than stock will cause your shocks to be mismatched. The Pro Kit is not quite as low as the Sportline, and a little bit lighter spring rate, but I wish I would have gone with the BMR Performance Springs (search on this forum).
One of the other members posted some useful spring rate comparison values (lbs/in);
GT: 160 / 668
GT PP: 165 / 728
BMR Performance: 170 / 740 (+3% / +1.5% vs stock PP)
BMR Handling: 300 / 980 (+82% / +35% vs stock PP)
CJPP: 182-217 / 799
Pro-kit: 200-314 / 800-914
Sportline: 217-331 / 879-994
Note that the progressive springs have ranges related to how deeply you are compressed (increasing), and with the limited suspension travel of these cars lowered, I would bet that they tend to run very quickly into the higher spring rates. Then you get the spring effect also of the bumpstops compressing and pushing back, which magnifies the effect. No wonder that the stock shocks can't keep up.
But if you're into stance first and performance second...Eibach Sportline is pretty awesome for that :shrug:
I think BMR recommended middle hole on front, stiffest hole in the rear (hehehe).I'm in the start of installing the springs and sway bars. What hole, performance setting are you guys choosing for sway bar? Mild ,all around, or the last hole for performance?
Any advice on getting out the stut to knuckle bolts? I got the nut off but the bolts are frozen in their? I'm going to use an air hammer on it tomorrow morning!!!
Anybody have any idea what the Steeda sway bars measurements are? I like the Hotchkis sway bar kit Front is 36.5mm rear 25.5mmSway bars make a HUGE difference in how the car handles and how much flatter it stays in the turns.
I have the Steeda sway bars and their billet mounts. What a big difference it made.
I don't believe the spring rates changed. What I have heard is that the struts/shocks have been re-valved.This is great information, but to clarify, are the GT PP rates listed for the 2015 or 2016. I was given to understand that things got tweaked on the 16 in response to customer complaints about wheel hop.
