Eibach pro dampers any experience?
Hsq91
California
Huy
19 Ecoboost
Has anyone installed Eibach pro damper shocks? Can't find much about them. They seem to be fairly inexpensive and are supposedly matched to the pro kit springs. How do they improve upon the stock shocks?
Järn
The Motor City
Tony
2019 Mustang GT Premium, Ruby Red, A10, B&O, AE
I have no experience with those springs however, the ride frequency calculation should tell you a lot. At the min rate, they are very close to the GT350, at the max rate they are close (the rear is) to GT350R.
You will need the best dampers to pair with these spring rates.
https://www.mustang6g.com/forums/threads/calculating-ride-frequency-for-the-mustang.146540/
Weght in Pounds:Front Weight DistributionUnsprung Mass %Unsprung WeightFront Motion RatioRear Motion Ratio
Variables:37050.530.12444.60.980.48
Sprung Front WeightSprung Rear WeightFront Spring lbs/inchRear Spring lbs/inchFront Ride FrequencyRear Ride FrequencyRear/Front RF RatioAverage Ride Frequency
GT non-PPOEM
1728​
1532​
160​
668​
1.32​
1.40​
6.28%​
1.36​
GT PP1OEM
1728​
1532​
165​
728​
1.34​
1.46​
9.25%​
1.40​
GT PP2OEM
1728​
1532​
198​
822​
1.47​
1.55​
5.98%​
1.51​
GTwith GT350 Springs (2016-2018)
1728​
1532​
194​
914​
1.45​
1.64​
12.90%​
1.55​
GTwith GT350 Springs (2019+)
1728​
1532​
211​
857​
1.51​
1.59​
4.82%​
1.55​
GTwith GT350R Springs
1728​
1532​
240​
914​
1.62​
1.64​
1.50%​
1.63​
GTSteeda Minimum Drop & Ultralite Linear
1728​
1532​
200​
800​
1.47​
1.53​
4.02%​
1.50​
GTJ&M Products Minimum Drop Sport
1728​
1532​
210​
815​
1.51​
1.55​
2.46%​
1.53​
GTSwift Spec R #4X914R (5/14 Kg/mm)
1728​
1532​
281​
784​
1.75​
1.52​
-13.12%​
1.63​
GT350 (2016-18)3760 lbs. (54/47 distribution) 12% Unsprung
1787​
1555​
194​
914​
1.43​
1.63​
13.96%​
1.53​
GT350 (2019+)3760 lbs. (54/47 distribution) 12% Unsprung
1787​
1555​
211​
857​
1.49​
1.58​
5.81%​
1.53​
GT350R3650 lbs. (54/47 distribution) 11% Unsprung
1754​
1527​
240​
914​
1.60​
1.64​
2.45%​
1.62​
GTBMR Performance (SP763/SP080)
1728​
1532​
170​
740​
1.36​
1.48​
8.52%​
1.42​
GTBMR Handling (SP083)
1728​
1532​
250​
980​
1.65​
1.70​
2.98%​
1.67​
GTSteeda Sport Progressive at minimum
1728​
1532​
150​
525​
1.28​
1.24​
-2.69%​
1.26​
GTSteeda Sport Progressive at maximum
1728​
1532​
180​
820​
1.40​
1.55​
11.01%​
1.48​
GTSteeda Dual Rate at minimum
1728​
1532​
220​
800​
1.55​
1.53​
-0.82%​
1.54​
GTSteeda Dual Rate at maximum
1728​
1532​
350​
1200​
1.95​
1.88​
-3.69%​
1.91​
GTEibach Pro Kit at minimum
1728​
1532​
200​
800​
1.47​
1.53​
4.02%​
1.50​
GTEibach Pro Kit at maximum
1728​
1532​
314​
914​
1.85​
1.64​
-11.26%​
1.74​
GTEibach Sportline Kit at minimum
1728​
1532​
217​
879​
1.54​
1.61​
4.68%​
1.57​
GTEibach Sportline Kit at maximum
1728​
1532​
331​
994​
1.90​
1.71​
-9.87%​
1.80​
