MrAjsTech
- May 20, 2016
- Central Florida
- 2016 GT, 2003 Cobra
For sale VMP Performance/FFTec Turbo Upgrade kit for 15+ EcoBoost. THIS KIT IS USED. Came off a 2015 Ecoboost that went 11.2 @ 120 MPH. The car was returned to stock. The turbo spins freely and is in good condition
$2900 Located in Central Florida
Message me for more pictures.
Details:
The VMP/FFTec turbo upgrade system features:
Superior Response and Spool-up Characteristic Utilizing Race-Proven Borg-Warner 7670 EFR Turbocharger
304 Stainless Steel Manifold/Adapter Flange Construction with Generous Full Radius Root and Cap Double Welding Technique
304 Stainless Steel Downpipe
Aluminum full-flow 3.5"" Compressor Inlet Elbow
Aluminum full-flow 2.5"" Compressor Outlet Pipe
Proven Durability through extensive testing: Over 10K mikes on our systems, and numerous track and dynamometer sessions at over 500 HP!
Each turbo system is built in house by FFTec's welding and engineering pros, following very strict quality control guidelines. Workmanship is outstanding!
Whats is included with your turbo system purchase?
Turbo Flange Adapter
Downpipe Heat Protection
Compressor inlet elbow
Compressor discharge pipe
Turbine discharge pipe and mid-pipe
Oil Feed/Drain Lines and Fittings
Water Inlet/Outlet Lines and Fittings
Heat Insulation Wrap
Turbo Blanket
Mounting Hardware (Nuts, Bolts, Gaskets)
Vacuum Hose/Tubing (Tee's and fittings)
Details:
Turbo Blanket
