Educate a noob: Why does the Coyote respond so well to boost?
wireeater
Virginia
wheelwell.com
Rich
Shadow Black 2019 Mustang GT Premium+ PP 6spd
When you have pressure but no flow it doesn't make horse power. Think of a pressure washer.
The Coyote head flows so much better than the LS it allows more rev and more rev means more flow and more flow means more power.
And what does more power mean...
Advertisement
5ABI VT
Gta
2015 mustang GT
s mentioned a few times it comes down to the heads.4V heads flow much more air. Variable valve timing helps too. With the pushrod motors the limitation is the stock cam being that it is designed for one thing.. a do-everything cam (emissions, driveability, power and torque and throttle response) so they are limited (one major drawback with pushrods as the Cam cant do as much as 4 cams and 32 valves especially with vvt). That's pretty much why you see 'blower' cams out there for the pushrod crowd. One advantage the pushrod crowd has is displacement. They will argue but its a fact that given equal displacement a 4v head will destroy a 2v head and pushrod architecture except for size (external dimensions) and weight.
I have a 93 corvette with a built LT4 (gen II) spinning 8500 rpm (sold roller setup) so im well versed in the limitations of a pushrod motor (I traded idle , response and low end torque for extreme top end torque/hp), also have a 94 LT5 zr1 corvette (has a Lotus dohc 32 valve all aluminum V8) which there are some strokers making 800+ NA. :cheers:
Ctease
GT350
11:1 is static compression ratio. Dynamic ratio can be lowered with VCT. Aluminum is pretty strong. Lot of computer analysis used to determine where to reinforce the block and where to reduce weight. Engine management is pretty good also.
I think most engines make good power under boost. Coyote has high volumetric efficiency. Effects of boost seem greater than other V8s. Turbo'ed S2000 can make 700whp on stock engine. That would be like making 1,500whp on stock Coyote. So it's all relative to who you compare it to.
16MustangVet
North Dakota
2016 mustang 5.0
Behold the damn magic of intake AND exhaust VVT!
ive linked this article before and ill do it again because its so impressive IMO.
http://www.stangtv.com/news/how-much-power-does-coyote-vct-account-for-aem-answers-the-question/
How Much Power Does Coyote VCT Account For? AEM Answers The Question
By Don Creason
posted on Feb 27, 2015
The Coyote engine relies on variable cam control to help it make power, and improve drivability. Ever since this engine was released however, there have been many who have “locked out” the VCT (variable cam timing) system in order to run aftermarket cams. As the engine has aged, and manufacturers have learned more about it, many are finding that locking out the cams is not always the best strategy.
The Coyote VCT system works by moving high pressure oil into a camshaft phaser, allowing the camshaft to be advanced or retarded during engine operation. Oil flow to the phaser is controlled by VCT solenoids, and commanded by the computer. The lockout devices often used for blocking the VCT typically limit the movement of the phaser, thus locking out its operation. Initially, when VCT was introduced on the 3-valve 4.6 and later on the 4-valve Coyote, there were few if any aftermarket engine management systems capable of controlling the Ford VCT system, especially when it came to controlling 4 camshafts.
AEM’s Infinity system was one of the first on the market that could control the Coyote’s VCT system. We used it last year on our Carb Coyote Cobra Jet build, and showed how effective it is when we made right at 2 hp per cubic inch, utilizing the VCT system, and tuning the engine with Infinity. This system is quickly becoming a favorite of a variety of racers and enthusiasts with hardcore builds, who need a powerful tuning element.
We used AEM’s Infinity system on our Carb Coyote Cobra Jet engine.
Some argue that the VCT system is just one more element of complexity from both a mechanical, and a tuning standpoint, and is not really necessary to overall Coyote engine performance. While, in extremely high RPM applications the VCT system is less effective, as we showed in our Carb Coyote Cobra Jet series, in the RPM range where these engines spend most of their time it’s vital.
AEM recently set out to show just how much power Coyote owners may be leaving on the table without the use of VCT. To do that, they tested a stock Coyote engine without VCT control, then began adding VCT first to the intake, then to the exhaust cams.
The testing conducted by AEM proves how vital the VCT system is. With no VCT, the Coyote engine peaks out at 6,500 RPM making 423.1 hp. With the intake only VCT, the engine only picks up 5.8 peak horsepower jumping to 428.9 hp at the same 6,500 RPM. With the exhaust VCT also activated, the engine puts out 465.4 hp at 6,500 RPM. This is where carefully studying the dyno information is valuable. A total gain at peak RPM of 42.3 hp might not sound like its worth the trouble of the VCT, but closer inspection shows a much bigger story. At 3,900 RPM the engine is making 109.3 hp more with the VCT activated than it was without.
The story is very similar, and perhaps even more dramatic in terms of torque. With no VCT the engine made 368.6 lb-ft at 5,400 RPM. With the intake VCT active, that torque jumps to a peak of 412.2 lb-ft, and the peak drops down to 4,400 RPM, torque stays above 400 lb-ft until nearly 5,400 RPM. Activating the VCT on the exhaust cam shows another substantial spike in peak torque output, taking total peak torque to 454.4 lb-ft at 4,400 RPM. That’s a gain of 85.8 lb-ft, at peak.
Once again with torque, the graph proves out how valuable the VCT is for torque as well. Take a look at the torque graph at 3,700 RPM. At that point we can see that with VCT, the Coyote engine is making another 149.9 lb-ft than without. Even at the horsepower peak of 6,500 RPM, torque with VCT active is still outrunning torque with it deactivated, with the engine making over 375 lb-ft at 6,500 RPM. The non VCT setup never outmatches the VCT activated setup for torque or horsepower, especially below peak where it matters the most.
Please actually click and open the article and look at the graphs the dyno graphs are worth more than words!!
Advertisement
5 - Hypermotive - 1
Advertisement
