Ecoboost High Performance Pkg 0-60 actual
Knerrpool
Virginia
2011 Fusion Sport
Greetings. I have test driven a 2020 HPP (automatic, no handling pkg). Per track apps, the best 0-60 time I could achieve was 6.5 seconds (in drag mode). Granted, this is probably using 87 octane and is on streets, not a track, but everything Ford has said indicates a sub 5 second 0-60 time (even 4.5). I'm hoping the 0-60 will improve over time (and with higher octane gas). Can owners please post what times they are actually achieving after having owned the car for a bit? I really like the car and I'm not expecting sub 5 times, but certainly would think it should be better than 6.5. Thank you.
Ebm
North Carolina
Guy
'14 GT
You already found your issue. 87 octane drops the regular ecoboost to 275 horsepower and 300 pound-feet of torque. On 93, the regular ecoboost is rated for 310 horsepower and 320 pound-feet of torque. I don't see the situation being any better for the HPP. It actually is probably worse. Plus, the actual 0-60 time is in ideal conditions.
Knerrpool
Virginia
2011 Fusion Sport
Thanks. Yes, I agree. I still would like to see what other HPP owners are actually experiencing after some time (with or without higher octane gas).
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
Don't forget to turn off traction control.
Deleted member
Guest
Please please please stop putting 87 octane in your eco. Just because you can does not mean that you should.
3oostdmstng
florida
2016 Mustang Ecoboost
I do not own an HPP but youre gonna have to add more details so that when those that own the HPP can help you better.
Did you test drive the coupe or convertible?
10r80?
How many miles in the car? Assuming that since it was a test drive - less than 100 miles in the odometer.
Temps / DA during your test drive?
Unfortunately 87 octane is a NO NO on the EB mustangs - performance wise.
As an EB mustang owner myself, from MY experience, I will say this: these EB engines get faster with MORE miles in them, and the longer youve been pumping 93 the better.
There's only ONE guy on youtube that has posted a 0-60 with his HPP. His best so far is 5.0 seconds , he wasnt pumping 93 octane, though.
Rated numbers are under perfect conditions for any car.
Bikeman315
Myrtle Beach, SC
Ira
Greeting Knerrpool and welcome to the forum. Are we to presume that this was a brand new dealer car? If it was why would you take a brand new car with no break in miles and thrash it with 0-60 runs? Add that to the fact that you already know it had regular in and you have a recipe for lousy times. Were you really expecting even close to advertised numbers? If you were, I have a bridge in Brooklyn to sell you. :crackup:
Now if this was a friends car that had been broken in, never mind. If it had regular in it your friend should trade it in for a Prius.
Newbies! :headbang::facepalm::)
Bikeman315
Myrtle Beach, SC
Ira
10r80?
OP just wants to know what others have run because he is concerned the one he drove was slow. He did say it was an A10.
3oostdmstng
florida
"Greetings. I have test driven a 2020 HPP (automatic, no handling pkg)."
You are very right LOL.
My bad!
FreePenguin
Ohio
Donald
17 mustang
what's actually faster? sport or track, vs sport or track with tc off? spinning tires takes away from propelling
Knerrpool
Virginia
2011 Fusion Sport
Yes, I am a newbie. I don't know what the actual octane in the car is - its a test drive with 50 miles on it. And I realize that I probably shouldn't have taken a few 0-60 drives (although I'm quite sure I'm not the only that test drives new cars this way). I'm not trying to be sophisticated here - this was on a regular flat dry straight road in the morning at 75 degrees. I did not expect the car to do anything close to 5 seconds. However, I DID expect it be at least around 6. Maybe 6.5 is right using the lower octane - I don't know. I'm just looking for what current owners are getting on everyday normal 0-60 times (with or without high octane) so I know what to expect later. At this point, my 2011 Fusion is modestly faster.
Knerrpool
Virginia
2011 Fusion Sport
Can you post a link to this? I can't find it. Thank you.
3oostdmstng
florida
Here:
At around minute 2: 45 he shows his ALL BEST TIME RESULTS.
I asked the guy and he said he wasnt pumping 93, he was under the idea that pumping less only affected TORQUE but NOT HORSEPOWER.
Anyway, Id expect better from the HPP, either way. However, at only 50 miles in the odometer and 87 octane I wouldnt expect greatness. In my '16 in 75F temps I actually achieved my all time best of 2.2 0-30 and 5.5 0-60 with a 1500 rpm launch. Always 93 octane. Stock ECU , btw. My worst 0-60 has been 6.1 sec in 92F temps no launch - just smashing the pedal.
Blue Moon
Maine, or eastern Canada
Pete
17 Ecoboost Perform Pack Std
My EB is a '17 model with PP and stick shift, and my best 0-60 is 5.4 seconds.
