Ebay sequential front signals
Ts2016
Pa
Todd
16 gt 89 gt
I purchased ebay front signals for 17 mustang. Have 1 plug and they said its plug n play. I plug it in and only 1 of the 3 lights on turn signals work. Then they only work if I have headlights on.. anybody run into this issue
thunderstrike
Montgomery, AL
2019 Mustang GT Premium 6 spd
Read the find print and if something's not as described, report it and ask for refund. If refused, open a case with eBay.
Ts2016
Pa
Todd
16 gt 89 gt
Ya I contacted seller they said everything should work. Sent another pair same deal
cactus_kid
Big Bend Country, TX
Michael
'21 GT (see sig)
Start the refund process. Don't wait.
Rapid Red
Woodstock GA
Greg
Maybe it ain't going ta work in your car.
"Then they only work if I have headlights on.." < so clear, is this suppose to mean headlights on they work normal, like turn signals ?
If yes you have a mismatch between the LED signal set plug and the car's plug you are trying to connect to.
Look at the stock (removed) signal set, make a note of the plug pin locations & compare the two. See if you can spot a difference .
If this sounds complicated, do as catus_kid suggest .
Plug & play sells a lot of stuff, should read "plug & play most of the time, but not always"
It is the electrical equivalent of "Bolts right on"
