Dissection of a B&O Amplifier
Weeee
Utah
Tom
Mach 1, Mach E GT
I bought a B&O amplifier from a wrecked convertible Mustang to learn more about what its hardware could support. I took these photos through a magnifying glass, so you will notice distortion along the edges. The blue stuff is a thermal paste that makes contact with the case, which is a massive heat sync.
Kudos to @omiga for the assistance in analyzing the components.
What B&O states on their website about the amplifier:
  1. 900 Watts (Ford Media states it is 1000 Watts)
  2. 10 channel Analog Amplifier
  3. Digital Signal Processing (DSP)
    • Speed Adaptive Volume
    • Surround Sound
    • Power Manager
Overall board:
Undocumented USB port:
  • Assumed purpose - communication with the DSP chip.
  • It appears to be a proprietary four-pin USB connection. It is present on every HARMON automotive amplifier I've reviewed.
  • Do you know what this is or where to get the correct cable? Post up!
NXP TJA1043:
  • Assumed purpose - Amp communication with the CAN bus.
  • High-speed CAN transceiver interfaces between a Controller Area Network (CAN) protocol controller and the physical two-wire CAN bus.
  • Link to the datasheet
TI CDCE913:
  • Assumed purpose - Phase-locked loops (PLL) for the Analog Device DSP.
  • I2C, Integrated EEPROM, Pin programmable, Spread-spectrum clocking (SSC).
Analog Devices ADAU1451:
  • This is the digital signal processor (DSP) chip.
  • There is plenty of vendor documentation, YouTube tutorials, and freely available software to tune this chip. I believe this chip is related to the undocumented USB port found on the board.
Cirrus Logic CS5368-DQZ:
  • Assumed purpose - noise cancelling.
  • 114 dB, 192 kHz, 8-Channel A/D Converter
  • The empty slot makes me curious.
NEC 70F3580(A1):
  • Assumed purpose - CAN bus
STMicroelectronics - FD21B:
  • Assumed purpose - Class D amplifier chip.
  • Unfortunately, the datasheet for this chip is unavailable. This suggests that it has been custom-made for HARMON Automotive. You can view the rest of their datasheets here if you'd like to get a rough idea of what they support.
  • All five have the same part number.
  • Each amplifier supports two channels.
Butterworth filters:
  • Each channel of the amplifier has one.
Microcontroller - Link to the details
  • Unknown purpose at this time.
No clue what is going on here yet:
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec
I bought a B&O amplifier from a wrecked Mustang to learn more about what its hardware could support. I took these photos through a magnifying glass, so you will notice distortion along the edges. The blue stuff is a thermal paste that makes contact with the case, which is a massive heat sync. I'll update this post as I learn more. Feel free to contribute!
Overall board:
The DSP:
Analog Devices ADAU1451 - Link to the details
One of the five amplifiers:
STMicroelectronics - TBD - Link to the catalog if you'd like to help look . All five have the same part number.
Very interesting. Thanks for the info :)
Weeee
Weeee
Utah
Tom
Mach 1, Mach E GT
I’ve been updating the top post with some additional items. A thread I’m pulling on is the DSP. The amp has an undocumented access port which I believe is for the DSP and its configuration. The current challenge is the proprietary or odd ball connector. I think this connector is HARMONs way to prevent tinkering. The DSP chip itself is well documented with YouTube videos available. I may end up removing the connector and replacing it with a standard USB type B.
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
From that angle, it does look like a misshapen usb.
Weeee
Weeee
Utah
Tom
Mach 1, Mach E GT
I was able to ID a couple of additional components today and have updated the 1st post. Additionally, I looked at numerous other amplifiers produced by HARMON. I confirmed they all have the unusual USB port, raising my hopes that it is for the DSP chip.
omiga
San Diego
Dimo
Mustang s550 GT convertible
    • Surround Sound
    • Power Manager
Overall board:
NXP TJA1043 - Link to the details
  • This means the amp is communicating with the car.
TI CDCE913 - Link to the details
  • This is the DSP chip. There is plenty of vendor documentation, YouTube tutorials, and freely available software to tune this chip.
Cirrus Logic CS5368-DQZ - Link to the details.
NEC 70F3580(A1) - Unknown purpose at this time
STMicroelectronics - exact model TBD - amplifier
  • Link to the catalog if you'd like to help look . They are an LQFP64 exposed pad-up package. Once we figure this out we'll know what each amplifier can support for speakers.
Thanks for the information; you nailed most of it.
I guess "TI CDCE913" is the PLL for Analog Device DSP. You can see the crystal to be soldered left of it. Why do they need that while the ADAU1451 has built-in PLL? This is also my question, but someone with experience with these DSPs and maybe the car can answer that question. Maybe they need it for spread spectrum functionality, or they didn't like the built-in PLL for another reason.
I checked Digi-key, and it turned out that there is no ST chip with 64-LQFP with exposed pads with any architecture other than Class-D, though I can't say precisely what that part is. They seem to be very conservative in sharing the data for these Amplifiers. That said, you also found that each chip comes with output filters, meaning it is Class-D.
That Renesans chip is weirdly always there. It's an old microcontroller, which I think is only there for the CAN bus. It has firmware that does something for them, and they don't want to add the same code to other MCUs that they do have on the board.
The "CS5368" is somehow related to noise-cancelling capability. That's the reason they have more wiring for B&O-enabled cars. For the empty spot, you should look to understand if versions of this hardware are sold for more noise canceling, etc...
Weeee
Weeee
Utah
Tom
Mach 1, Mach E GT
There you are @omiga! What do you think is going on here?
omiga
San Diego
Dimo
That's a shielded transformer; it should boost the power supply as the car battery is 12V. They might need a higher voltage because P=V^2/R. So, for a fixed resistance, if you need to put more power over the load, you need to increase the voltage.
Suppose you need to understand what's the actual power supply voltage. In that case, you either need to power it on and measure it or find the boost converter chip and feedback network and, based on the resistor's value, theoretically find out the output voltage (typically, it's a resistive network outside that sets the output voltage).
I don't know which chip there is the voltage booster.
