TnWHTMARE
Planning on hitting the drag strip again Friday night and this time with some M/T's. I'm curious about your experience on how disconnecting the "traction control" connector at the airbox effects the track apps...and more specifically, Line Lock. I pulled the connector this morning and my track apps were unavailable. Has that been your experience?
Once I plugged the connector back up, they were available. This seems to make sense. However, I still cant access Line Lock, which I think may be a second issue. The tire pressure light is on because I have the race stars installed. So I can only assume that the Line Lock cant be used if the TPMS light is on??
Just curious because I was hoping to pull the TC connector to make sure no nannies were active at the track but if I plan on using the line lock, it looks like I cant do that and may be a moot point anyway if the TPMS kicks the lock also. Any input is appreciated.
. They work on radio frequency proximity. Then when you leave after certain time/miles it can't find them anymore.
