Digital dash cluster
spuon
minnesota
Lucae
2016 mustang gt premium
will a 2019 digital dash cluster that came from a parts car fit in a 2016 mustang gt. will i need other parts or will it plug and play?
COYOTE1952
POINT CLARE NSW SYDNEY AUSTRALIA
LOU
2017 MUSTANG GT 5.0
hi i installed a DIGITAL DASH ON MY 2017 MUSTANG GT, there are lots of videos on you yube to show you how, i thought it was very simple, two things to take into consideration 1 you will need to programme the cluster and you will also need a new clockspring if you are buying second get get both from the same car. you can use a programme called FORscan to programme it if you are worried about doing it yourself there are people selling these digital dashes already programmed.
Sycostang67
Kuna, ID
1967 Mustang, 2015 Mustang, 2001 Ram, 2012 Wrangle
You will also need the steering wheel buttons. Trimming inside the dash is required as well, a bit messy but easy enough. Aside from the programming part it is mostly a bolt in swap.
