Difference in OEM splitters and belly pans.
Dadsreward
2017 EcoBoost Premium PP
I am a bit confused on how many different splitters and belly pans are available from the factory. Standard, GT, GT Performance, EB Performance, CS... Are there any more? What is the difference in these and which belly pans work with each?
Thanks in advance and sorry if this has been discussed. If so can someone just share a link to the thread as I could not find anything.
Bump
I'd like to know as well (even though I have an EB Prem. w/PP)
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I'll take a stab at this.
3 Splitters are Standard (thin profile), Performance Pack (larger profile), and California Special (larger profile).
Performance Pack splitter requires the PP belly pan, and different fender liners.
CaliSpecial splitter is chosen when you want the PP style splitter, but have the standard belly pan, because it bolts right up.
Here are some thread for further research:
GT PP Splitter and Belly Pan Install
Installing true PP belly pan and true PP splitter
Ordered PP lip and belly pan
Includes brake chute mod
PP Belly Pan Help**
California Special Splitter Install
Dadsreward
Dadsreward
PP Belly Pan Help**
Thanks for the info! Where does the EB with performance package fit in with this? I originally thought it had the same splitter/belly pan as the GT with performance package, but my understanding now is that is not the case. Would the California Special splitter be a direct bolt on or is a new belly pan required?
wildcatgoal
@sirboom_photography
TBD
The California Special splitter is a bigger profile but does not look the same as the PP spliter, which has a sort of vertical part on each side where it ends in front of the wheel. Frankly the CS splitter looks better, IMHO. Why Ford opted for 3 separate splitters baffles me.
EB PP does not have the GT PP splitter, at least not on any I've seen. Therefore you'd get the CS splitter if you wanted a bigger splitter. Call Levittown - they have a CS and a PP package you can buy. Or contact them on this forum.
GTP
Deutsche Pony
Indy
Philip
After you read the threads I referenced, you will learn that the PP belly pan does not use the rubber strip, has an access cover for the oil filter, and has two scallops to direct air to the inside of the wheels for brake cooling.
I am installing the CS splitter, and skipping the cost of the belly pan and fender liners.
