Desperately need Suspension Help
Mootang
Sacto, Caliunicornia
Henry
2017 Mustang GT
What other mods do you have on your car besides the Cradle Lockout kit and Vertical Links?
D.Brown
D.Brown
Save the Manuels
Rhode Island
David
15' GT
Also, [MENTION=10281]BmacIL[/MENTION], is it possible that I damaged my shocks by having an incorrect length of bumpstop on them?
jbailer
Joe
I don't think so. If it were possible, I think mine would be trashed. I didn't cut my factory bump stops for a long time. By the time I pulled them to trim, they were trashed. I cut them down which improved the ride but then switched to the Steeda adjustable bump stops and improved even further.
Jon|3.7
Houston, Tx
15' 3.7 Mustang
did you install new bumpstops? or you only have your stocks? i thought you installed new ones, so i thought it might of been the problem i had
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
No I don't think so unless you did some offroading or went over a lot of railroad tracks several times a day lol.
D.Brown
D.Brown
Save the Manuels
Rhode Island
David
15' GT
No idea what happened, but after I reassembled the car and checked all of the torque specs my car now pulls to the right. The only thing I did was cut the bumpstops and put my summer wheels/tires back on. What in the world is going on with my vehicle???
BmacIL
Enginerd
Naperville, IL
How did you store the tires? I had a set do that to me before it would pull under power.
D.Brown
D.Brown
Save the Manuels
Rhode Island
David
15' GT
I had them stored in boxes in my apartment. Maybe it's the tire pressure. I didn't mark what corner they came off of either. I'm trying to figure out how I can tell without trial and error and lots of wheel swapping. That would suck if I need new tires. I just bought these.
D.Brown
D.Brown
Save the Manuels
Rhode Island
David
15' GT
Should I order Steeda bumpstops along with the rear shock mounts? Also, do you think I should switch over to a better suspension system than the FRPP/Steeda Linear combo while I'm at it?
jbailer
Joe
For the bump stops, the question is how much are you hitting on them now. For some reason even with my bumps stops cut to the recommended size I was still hitting them frequently. Not that it's a problem but with the factory stops cut that low, there is a hard plastic black retaining ring there that makes it pretty rigid. I switched to the Steeda bump stops which are just a little shorter than the recommended trim height and it was a great improvement in my ride quality.
D.Brown
D.Brown
Save the Manuels
Rhode Island
David
15' GT
I was wondering the same thing, since the amount I took off left just the plastic ring and the above softer material. They're not all that expensive, and easy to replace if I'm doing the shock mounts anyway. I just figured while I'm under there, it might be worth changing to a different setup, especially since there are four types of shock mounts.
BmacIL
Enginerd
Naperville, IL
Absolutely nothing wrong with your spring and damper combination together. Maybe grab the steeda stops since they're pretty inexpensive along with the mounts.
D.Brown
D.Brown
Save the Manuels
Rhode Island
David
15' GT
Thanks again for all the help. I owe you a beer.
