Dead pedal cover
mustang mick
NSW Australia
2016 mustang gt race red fastback (ordered)
Thinking that probably an hour with the hair dryer wasn't enough, I don't know. Should have had it there before the first time application me thinks. Could have been a different story I guess. Anyway...
MaxQ
2016 Oxford White 5.0 GT
Back on post #9 I fitted the americancraft dead pedal cover , it came with 3M primer to help bond the 3M adhesive to the plastic, hasn't come off so far.:thumbsup:
phil545
Phil
2016 Mustang GT
Thanks for this guys, so im thinking with mine, ill clean the plastic on the car stick it on and then hair dryer it heaps to get it nice hot and stick better? Is that right?
mustang mick
NSW Australia
Go back a page on the thread Phil, you will see my experience in a long winded story. I used heat but probably too late. Like Copie said on the previous page you really need a hair dryer or heat gun if the ambient temp is only 15 degrees. Just be careful with the heat on the plastic though!
phil545
Phil
2016 Mustang GT
thanks mate, i read your post but got a bit confused. will use the heat once i stick it on and see how it goes, all else fails ill super glue it on lol
Copie
In a steel box
2017 Ford Mustang GT
Heat before you stick on until the plastic is warm (not hot) apply then a touch more heat.
Bonus points if you leave something heavy on it (brick) for a little bit to aid in the adhesion.
phil545
Phil
2016 Mustang GT
Good shout, thanks mate, mine arrived today so ill fit this up shortly
OaG_sGm
Melbourne
Ray
2016 Mustang GT 6-speed Manual AUS
Haha
I have been giving these out as a small gift to my Tribar DRL installation customers.
And yes the RHS versions are narrower. But I put a bit black insulation on the right, and use some good glues and they look very good. Just as stock.
phil545
Phil
2016 Mustang GT
Installed mine last night, about 10 mins with the hairdryer on the foot rest. about 5 mins on the cover (with the tape peeled) and on it went. Held it firmly for about 30 second and then set up a few props to apply some weight to it. Seems like its stuck good!
Copie
In a steel box
Yes heat and prep the footrest is the key, for mine i wiped it down with iso alcohol, used a heat gun on it for a few min to get it warm to the touch (also leaving it out in the sun will work, both the cover and the car) then peeled the 3m tape with tweezers and applied the cover.
dtdazza
NSW
Darren
Mustang GT TY
Installed the cover today in the cold but it is holding so far.
Definitely looked better next to the other pedals.
ian b
Sydney
Ian
GT Manual Deep Impact Blue
easier if you pop off the pedal before you fix.
3 clips so easy to remove and refit once the cover is fitted.
WD Pro
United Kingdom
Lime GT
I know, I’m reviving an old thread …
Has anyone recently bought a RHD dead pedal cover that fits perfectly with no modifications and matches the other (three … lol) pedals ?
If so, please could you share a link ?
Santa wants to put one in my stocking for me from the kids … :like:
Cheers,
WD :like:
WD Pro
United Kingdom
Lime GT
Finally got one sorted, although it took a bit of fettling to look, fit and stick how I wanted it to :
WD :like:
