Damage to shift fork pads with MGW?
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Does anyone know if the MGW shifter or the transmission has stops built in to prevent damage to the shift forks or pads? I know the stock plastic pads are likely to be damaged with the stock shifter. I am curious if they are more or less likely to be damaged after an aftermarket shifter is installed. I would love to hear what you guys have to say.
pinero61
Houma, La
'15 Ruby Red Base GT PP
I damaged mine with the stock shifter. Trans was replaced under warranty, and MGW went in at the same time. Haven't had an issue since.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Do you know if the MGW has stops built in to protect them?
pinero61
Houma, La
TBH, no clue. Just saying that I haven't had the issue you're describing since I installed my MGW.
ForTehNguyen
Houston, Texas
15 GT
thought damage to the forks happens when you are trying to force it in during a lockout. MGW wouldnt have lockout because its aligned all the time
kcc0521
Falls Church VA
Bo
2015 Black GT PP
You may be right I am new to the MT-82. I assumed the damage was the stress put on the part under hard shifting. I assumed an aftermarket shifter would increase the stress because the shock absorbing rubber in the stock shifter is removed. I may be completely wrong though.
Epiphany
Global
I like to disassemble things.
MGW doesn't eliminate the bushing between the main shifter arm and the transmission body (some others do).
15onBOOST
NYC
LOW n Sleek
mt 82 issues since early coyotes nothing to do with shifters. Hit up Ben Calimar he beefs up tranis PA location
