custom wastegate springs
trippleyelo
vancouver wa
ford f250 turbo diesel and 2016 mustang svo
ALL IN ONE THREAD ...:cheers:
IWG75 Ford Mustang 2015 Turbonetics NXT 2.3L Ecoboost 14ps
TS-0622-1003
The Turbosmart Ford Mustang Turbonetics NXT Internal Wastegate Actuator (IWG) has been developed as an additional bolt on upgrade to the Turbonetics NXT turbocharger kit for 2015+ Ford Mustang vehicles allowing for even greater levels of performance, this provides better turbo response and greater sensitivity when managing boost pressures. Designed as a direct bolt-on replacement for the Turbonetics kit, the Turbosmart IWG is easy to install and requires no special tools or fabrication.
WG38/40/45/IWG 7PSI Outer Spring Brown/Pink
TS-0505-2006
Spring - Suit Turbosmart Ultra-Gate38 (38mm), Comp-Gate40 (40mm), Hyper-Gate45 (45mm) External Wastegates, and Internal Wastegate Actuators (IWG:cheers:
WG38/40/45/IWG 10PSI Outer Spring Brown/Blue
TS-0505-2005
Spring - Suit Turbosmart Ultra-Gate38 (38mm), Comp-Gate40 (40mm), Hyper-Gate45 (45mm) External Wastegates, and Internal Wastegate Actuators (IWG-75). :cheers:
WG38/40/45/IWG 11PSI Middle Spring Brown/Red
TS-0505-2004
IWG-75 - Ford Mustang 2.3 EcoBoost - 12PSI
TS-0622-8122
Turbosmart's 12PSI Internal Wastegate Actuator for the Mustang EcoBoost creates a flatter boost curve which comes on sooner, with more stable boost and less drop off at the end of the rev range compared to the stock actuator. The result is a more driveable car with smoother power delivery and less turbo lag. Tuning is required with this product. :cheers:
IWG-75 - Ford Mustang 2.3 EcoBoost - 10PSI
TS-0622-8102
Turbosmart's 10PSI Internal Wastegate Actuator for the Mustang EcoBoost creates a flatter boost curve which comes on sooner, with more stable boost and less drop off at the end of the rev range compared to the stock actuator. The result is a more driveable car with smoother power delivery and less turbo lag. Tuning is required with this product. :cheers:
IWG-75 - Ford Mustang 2.3 EcoBoost - 7PSI
TS-0622-8072
Turbosmart's 7PSI Internal Wastegate Actuator for the Mustang EcoBoost creates a flatter boost curve which comes on sooner, with more stable boost and less drop off at the end of the rev range compared to the stock actuator. The result is a more driveable car with smoother power delivery and less turbo lag.:cheers:
vargas wastegates :cheers:
ready to install.
Please choose from domestic, or international shipping.
19psi and 15psi available
EBM Upgraded Wastegate Actuator
Product Code: VTT-Ebm iwg
This is an upgraded wastegate actuator for your Ecoboost Mustang. It will allow you to run higher boost with a smoother , more stable boost curve, while curing the part throttle surging issues some EBM's experience.* It will also hold more boost to redline, as the stock unit just cannot hold tension as back pressure builds. The actuator is a direct bolt on with no modifications to the car, or turbocharger needed, it comes preset to the preload level we suggest.* Simply remove the C-Clip, and the two bolts holding the factory actuator, and install the new actuator. We suggest a tune revision be run with the actuator as it can show overboost codes without it.
trippleyelo
vancouver wa
vargas turbo do want to add your waste gates:headbang:
EcoBOSS
Tejas!
2015 EcoBoost Premium, PP, 50th, RR
So, has anyone tried these different springs to provide feedback?
VargasTurboTech
Hayward, CA
Turbo everything
Sure, add ours. They are prob the best of the bunch, with two different options.
trippleyelo
vancouver wa
Yes..
Can you be more specific on what you want to know ..or you can ask Adam he's sold plenty; to forum members.lol:cheers:
