Cool Feature
PortalMaker
MD, USA
'16 Lexus IS300 AWD
You know the difference in using the 2 handles to tilt the seats forward?
- Side handle: Using this handle you'll have to manually find your sweet spot again.
- Seat back handle: Using this handle will put the seat back to the exact position you had it in previously.
souprmage
Portland, OR
2015 Mustang GT w/PP 50th Appearance
I'm not noticing mine going up or down, but my memory settings are all at the lowest the seat goes. My seat only moves forward and back on entry/exit. Maybe try resetting all your memory configs??
Just tap the start button with your foot off the clutch and it will go into accessory mode and move the seat for you. Then, you can push the clutch and hit the button again to start the car.
No, I mean I specifically set my #3 to go all the way back and all the way up, it makes getting out easier. My normal seating position is low and a bit forward. I just wish it changed height first when moving down. I'll probably just set my #3 to be all the way back, and leave the height the same, so it's not an issue.
HalfMoon
Brand Agnostic
West Coast
2016 Corvette Z06/Z07 2017 Camaro SS 1LE
Ah... okay, that makes sense. As for the starting the car though, try tapping the start/on button w/o the clutch held in and it will move the seat up for you.
