klauberm
- Mar 17, 2016
- Naples Florida
- Matthew
- 2019 Kona Blue Mustang GT Convertible
To create the foam pad I went to HDepot and found a sponge & double sided tape for under 10 dollars
Cut it down to measure 3x6x1.5 & apply double sided tape
Start with removing the back seat bottom and back so you can access underneath the convertible top deck.Your rear seat cushion (where your butt goes) simply pops out of the car. There are two clips you have to press down to get it out. The clips are located just under the front edge of the cushion, one on each side. Push them and then pop the cushion out. Remove the two bolts one on each side of the seat back and then lift up on each side to unhook the seat back. At this point you now have access to place the foam under the deck.
Location of the foam block is key, start by raising the top until the bottom of the back window touches the deck. Take a piece of masking tape and mark that point, now place the top back up.
Remove the double sided tape on the foam block and carefully reach between the deck and the covering. Place the foam long ways with the car so the foam is center to the tape mark as well as center to the car.
I needed to change both clips on the support brackets because the locking tabs on one side were broken off, the part # for each clip is FR3Z-76422B34-A
Cycle the top a few times to confirm the brackets stay in and then re-assemble the back seat.
This resolved my issue with the brackets popping out, I want to give a special thanks to RACERTTX for his assistance in this repair.
