Code p420 general code. Catalyst
Buhbuhj
NY
2015 EB Premium
Still got a code after installing my full race catted pipe. I put a o2 sensor spacer on the downstream sensor and it's been fine since. Didn't need the elbow, just a straight spacer.
edit: OAR shouldn't be dropping, you need tune adjusted to fix that or something.
hmdballa219
Lake Station, In
2018 shadow black mustang GT
Right That's what everyone's saying but it's a stock OTS stage 1 93 octane cobb tune So I don't understand why it drops...
Can u put a link where u got it. Or point me to the right direction please.
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
What brand of gas are you running? Please don't say Shell. If your OAR is dropping, that's because it's picking up knock. The OTS tunes are pretty conservative, so I wouldn't think it was a tuning problem. Trying running out all the current brand of gas you've been using (down to 0 to empty) and try using a different brand.
If an e85 station is close to you, try adding one gallon of e85 and filling the rest with 93. That'll bump the octane slightly and be a good indicator that you've been running crappy gas. That is, if the OAR goes to -1.00 and stays there.
hmdballa219
Lake Station, In
Usually speedway 93...but I think it's fine because I reset it..it drops to -0.75 then rises back up to normal -1.00.within about 15 miles. No clue why it drops tho. But yes I will do that then ...run it almost empty and add a gallon of e85 and the rest of BP 93 Oct.
Juben
Chattanooga, TN
Justin
So, let me make sure I'm understanding you correctly.
The OAR is dropping back down to -0.75 after you reset the ECU or reflash the tune? If so, that's normal for the OTS in my experience.
As long as it's not dropping to -0.75 after you drive it around or at random times, then you're fine. The OAR can be set to start at any value. Most tuners set it to start at -1.00. Cobb doesn't set it all the way to -1.00 right off the bat (from what I've seen and experienced back when I tried the OTS maps out).
Now, here's something interesting to note. Throwing in a gallon of e85 at each fill-up will make an e15 (15% ethanol vs 10% ethanol for regular pump gas) mix. e15 is 94 octane. You can do that as much as you want without ill effects and it'll give you a little extra buffer against detonation/pre-ignition. That's a great benefit to have on any car that's being tuned for additional performance.
If your Speedway has e85, I'd suggest trying it. I've tested the e85 content at a bunch of Speedway stations across Tennessee and it always tests out to be about e90. I always through in a gallon of e85 if I'm gonna run pump (93).
